Old 01-08-2015, 08:12 PM   #15
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
About this much
/illustrates with hand gestures
Whatabouteggs is offline   Reply With Quote
The Following 2 Users Say Thank You to Whatabouteggs For This Useful Post:
2much (07-02-2015), hmong337 (01-08-2015)
Old 01-10-2015, 12:19 PM   #16
sandman126
Slide Ways
sandman126's Avatar
Drives: 2013 SWP BRZ, 85 VW Golf
I run 10psi on my 91 tune and 15psi on E85 using a precision 5130
sandman126 is offline   Reply With Quote
Old 01-10-2015, 05:00 PM   #17
Whatabouteggs
[Citation Needed]
Actually I think it's been established that the limit on stock engines with an excellent tune and 93 is 9psi without causing a lot of damage. On something with no supporting mods and an ebay turbo kit? Maybe 5.
Whatever, this is a dumb thread.
Old 01-10-2015, 05:44 PM   #18
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
The quality of the kit has pretty much nothing to do with the amount of boost you can run. That is mostly the tune and fuel. 9psi on 93 being the most without causing damage is not true either. Many many people are running 12psi or so, several 16psi+, and at least one (myself) have run 22psi without breaking anything at all.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 2 Users Say Thank You to woode For This Useful Post:
Travisty75 (01-10-2015), trsiidno (01-10-2015)
Old 01-10-2015, 07:58 PM   #19
sw20kosh
Drives: 2013 Black FR-S
Didn't you say a lil while back that you think something is broken in your engine?
Anyways, you have proven that you can run 22 psi and retard the snot out of the ignition timing to do it on 93 octane. It can be done. Is it advisable? The 4 tuners that I have talked to (that have also tuned my car) say "hell no". Your tuner obviously says its ok.
The ones that I have talked to all agree that you get to a certain boost level where increasing the boost more just causes too much timing to be pulled that it just isn't worth the risk of raising your EGT's like that and stressing the (originally NA high crompression) motor out. If the engine was built for huge boost then it might be a different story.
But glad yours is still running strong and I am really curious as to how your setup would fare doing hot laps on a road course. It would show just how tough this FA20 is. As it stands, here in CA, turbo guys at the track are weary of going anywhere above wastegate spring pressure. Most of us are running somewhere in the 6-9 psi on E85 or 100 octane (keeping it right around 300 whp) to have some insurance that the motor stays together for prolonged track use.
The Following User Says Thank You to sw20kosh For This Useful Post:
Tenament05 (01-10-2015)
Old 01-10-2015, 09:54 PM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I'm running approx. e^x bars of boost.
x is how ballsy I feel that day.
Old 01-11-2015, 10:09 AM   #21
woode
Boosted Member
woode's Avatar
Nothing wrong with my engine?
I have a little bit different setup and moved a couple months ago and am running mostly 13psi now tuned by PTuning (side note: awesome guys.). I never claimed that it would last prolonged track use.. in fact I have stated many many times that that is the million dollar question to factor in - how is one going to actually drive the car? For a daily driver 12psi and maybe higher (I did it at 22psi for just under a year) can hold together just fine.
My whole point is that you can't just slap a generic hp/tq/boost/etc number on and say that is the limit. This platform has had stock engines blow at 200whp and others live at 500whp+.
Darryljr11 (01-11-2015), raven1231 (01-11-2015)
Old 01-11-2015, 12:13 PM   #22
sw20kosh
What is your setup now and how much power are you making at 13 psi? I've been tuning with Toan for 6 months or so. Awesome tuner!
Old 01-11-2015, 12:47 PM   #23
woode
Boosted Member
woode's Avatar
~322hp, botched FA20Club kit that has been mostly fixed. Slowly piecing together a new (lower compression) engine and then going to switch to either the 335 or a PTuning kit - hopefully by spring. Although, a kid on the way now so that might be delayed even more..
Old 01-11-2015, 02:29 PM   #24
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Quick, switch to both before the kid comes! Get a 335 and slap on that gt3076
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
Dream20b (01-22-2015), woode (01-11-2015)
Old 01-12-2015, 10:34 AM   #25
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
According to Crawford's YouTube posting of their white boosted FRS with upgraded internals no amount of boost is safe for this high compression engine. ..... They also sell fa20 engines with lower compression so I question their intentions.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following User Says Thank You to Boofneenee For This Useful Post:
Old 01-12-2015, 02:01 PM   #26
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
More likely that no FRS is safe in Crawford's hands.
The Following 5 Users Say Thank You to King Tut For This Useful Post:
Boofneenee (01-12-2015), sw20kosh (01-12-2015), Tenament05 (01-12-2015), Whatabouteggs (01-21-2015), woode (01-12-2015)
Old 01-12-2015, 04:28 PM   #27
ft86me
ft86me's Avatar
Drives: 2013 FRS
Stock injectors
stock fp
jdl turbo kit with 4854 base turbo
91 octane 13psi wot 6 to 8 half or partial throttle
no problems
before jdl turbo kit,
vortech w 12psi pulley
stock injectors
stock fp
91 oct
no issues
car has over 30k with about 24k boosted.
ft86me is offline   Reply With Quote
The Following User Says Thank You to ft86me For This Useful Post:
Old 01-12-2015, 06:38 PM   #28
sw20kosh
This.
Boost up my car bomexq Forced Induction 66 03-10-2014 07:32 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
E85+boost subatoy Forced Induction 5 11-06-2012 11:55 AM
