Old 12-29-2014, 08:23 PM   #1
ogrowup
Drives: Asphalt build in progress
Kartboy short shifter noise
Had a kartboy short shifter installed ( don't give me crap, I have no mechanical skills) by a reputable shop.
There is some noise in the gearbox now, is that normal?
ogrowup is offline   Reply With Quote
Old 12-30-2014, 02:56 AM   #2
breadcrumbz
breadcrumbz's Avatar
Drives: 2013 FR-S 6MT
I believe rattling is a common issue with the kartboy. The only reason I haven't messed with my shifter .
breadcrumbz is offline   Reply With Quote
Old 12-30-2014, 03:08 AM   #3
slim blanco
slim blanco's Avatar
Drives: 2017 86
so far so good with mine. 8k miles of use.
slim blanco is offline   Reply With Quote
Old 12-30-2014, 03:12 AM   #4
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Describe the noise. I have rattles and a resonance above 4k rpm but it doesn't really bother me one bit.
Decay107 is offline   Reply With Quote
Old 12-30-2014, 05:11 PM   #5
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
rattle
I just installed one in my car and had the rattle. I called KartBoy and they told me to make sure that the ball socket had alot of grease and to install the 2 o-rings that come with the shifter onto the pivot shaft on the shifter arm from the tranny. I was only able to install one o-ring but that eliminated most of the rattle. Then I added a heavier shift knob and that got rid of the remaining noise. It also helped with the shifting. I can almost guarantee that the o-rings were not installed. Good luck!
Caspeed is offline   Reply With Quote
Old 12-31-2014, 06:24 AM   #6
ogrowup
Thanks- I will check that out asap.
The noise is not horrible, but if it doesn't have to be there, I will eradicate it.
Old 12-31-2014, 07:05 AM   #7
BRZFern
Drives: 2013 SSM BRZ
Try this: Remove your shift knob. This will expose a screw with an allen head where the threads to screw the shift knob is. Remove screw with an allen key. Remove the spring for the reverse lockout from inside the shaft. Apply grease to the spring and use a syringe to inject grease into the shaft. Insert spring, screw in the allen screw, screw in shift knob. This eliminated all rattles at any rpm for my kartboy ss. Note: After you're done, pump the reverse lockout a few times. Wipe excess grease that will come out from two holes each located on the front and back of the lockout.
BRZFern is offline   Reply With Quote
The Following User Says Thank You to BRZFern For This Useful Post:
Caspeed (12-31-2014)
Old 12-31-2014, 10:34 PM   #8
ogrowup
Mystery solved
Turns out the noise is related to my new ACT HDSS clutch and Flywheel. The noise is normal. It's not a bad noise, just a new noise... kind of like a faint rattle. Since the turbo, headers and turbo back 3" exhaust were installed, there is a symphony of new noises. It is def loud as shit, pretty damn aggressive. All good.
The Following User Says Thank You to ogrowup For This Useful Post:
raven1231 (01-01-2015)
Old 01-01-2015, 10:15 AM   #9
Caspeed
Caspeed's Avatar
Originally Posted by ogrowup View Post
Mystery solved
If you're asking for help with an issue you should really include the other mods that were done to the car. It's a waste of time if you only mention one mod when you have made other significant mods.
Old 01-01-2015, 04:57 PM   #10
ogrowup
Yup got it
Caspeed (01-01-2015)
KartBoy Short Shifter DIY and Review F1point4 DIY (Do-It-Yourself) Guides 274 06-02-2017 05:48 PM
FS: Kartboy Short Shifter lickitysplit Interior Parts (Incl. Lighting) 2 11-11-2014 07:27 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
Kartboy Short Shifter phatpanda Transmission and Driveline 8 03-22-2014 12:45 PM
Kartboy Short Shifter Issues Yruyur Engine, Exhaust, Transmission 13 01-27-2014 01:19 AM
