Old 12-29-2014, 07:40 PM   #1
Bergen23
Drives: '15 Halo FR-S
AT not rev matching?
Tried searching for this and couldn't really find anything. Apologies in advance for anything that isn't proper terminology, learning as I go along here.
So, I understand the AT rev matches on downshifts. Coming from driving a manual, I used to downshift quite often when I would come to a stop or slow down. Normally, I get the nice throttle blip when I pull the paddle to downshift. I've noticed that after driving for a while (today I was driving about an hour and a half, and this happened around the hour mark) the car doesn't really rev match and it becomes sluggish when down shifting. After playing around with different combinations of driving modes (sport, sport vsc, track off, in D and in M) nothing really changed for me.
Anyone have a solution for this?
Bergen23 is offline   Reply With Quote
Old 12-29-2014, 11:18 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
What RPM and gear are you currently in when you do this?
N1rve
Old 12-29-2014, 11:25 PM   #3
Bergen23
Been through the range from 6 down to 1. RPMs between 2k to 5k. What happens is, when I pull the paddle, the RPM drops down, the engine/trans hesitate, then it downshifts without the cool throttle blip.
Old 12-30-2014, 12:45 AM   #4
navanodd
Drives: 2013 BRZ Sport-tech WRB
Weird. I've noticed similar behavior, but only when the trans is cold and leaving the torque converter unlocked. Does it seem like your torque converter is locking?
navanodd is offline   Reply With Quote
Old 12-30-2014, 01:25 AM   #5
Bergen23
I honestly don't know what that feels like. Best I can describe it is hesitation with a lazy downshift once the RPMs settle
Old 12-30-2014, 02:37 AM   #6
navanodd
You can tell if your torque converter is unlocked by increasing/decreasing the throttle briefly and seeing if the engine RPMs change a bit without any corresponding change in speed.
The torque converter is a fluid coupling and acts sort of like a partially engaged clutch when not locked. When the torque converter is locked, there is no slipping and the entire drivetrain feels much more responsive. Normal operation (warmed up) for the FRS is for the torque converter to lock after the shift from 1st to 2nd. It only unlocks otherwise when slowing down at low engine speed.
Old 12-30-2014, 03:34 AM   #7
whataboutbob
AutoX-10/10ths every run
If the downshift is going to over rev the motor, it will queue it and make the shift when it is safe, otherwise it will make the shift very quickly after inputs. In full auto mode, if you hit the brakes really hard and slow the car down a lot, it'll do the cool blip down shift.
Build thread:Here
Old 12-31-2014, 05:30 PM   #8
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
3 years come may and I have never seen this issue. As far as the que goes. I can actually plan my runs around it for autocross. For the times I need to get back into first that is. Other people who drive the car thats not used to it gets frustrated when they cant shift into first.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 12-31-2014, 06:54 PM   #9
Bergen23
That's not the issue here. I'm not going to over rev. The engine just seems like its lazy and doesn't want to make a quick downshift.
Old 09-07-2015, 02:47 PM   #10
aa_chow
aa_chow's Avatar
Drives: 2015 FR-S, 2020 Mazda 3 Sport
I have experienced what you said twice, both times are longer spirited drives. It stops rev matching without throttle, but seems under throttle. Back to normal after restarting the car. Anyone else can chime in?
aa_chow is offline   Reply With Quote
Old 09-07-2015, 03:36 PM   #11
Bergen23
I've now found its correlated to cruise control. Verified in my own car, and a brand new 2016 on the dealers lot.
Old 09-07-2015, 04:49 PM   #12
redmoon
Drives: 2015 LR Subaru BRZ
I have also experienced the same thing with at times the downshifts don't rev match. Bergen23, can you explain your findings on how it is correlated to the cruise control and whether you have a solution. Thanks bud.
redmoon is offline   Reply With Quote
Old 09-07-2015, 04:52 PM   #13
aa_chow
aa_chow's Avatar
Please explain!
The Following User Says Thank You to aa_chow For This Useful Post:
drewbot (09-07-2015)
Old 09-07-2015, 07:45 PM   #14
Bergen23
No idea how it's correlated. But after around 400km driven this weekend on my car, I had zero rev matching issues, except after using cruise control at speeds over 80kmh. It's clear that this is an electronics problem and not mechanical.
Just glad that I found where the problem starts. I was planning on leaving my car at the dealers for the day, but they wanted me to raise my suspension and switch back to stock wheels and tires and I had zero desire on doing that, so I won't be finding the solution to this.
The Following User Says Thank You to Bergen23 For This Useful Post:
roddy (09-07-2015)
Matching HID's and DRL's red_ZN6_4_you Cosmetic Modification (Interior/Exterior/Lighting) 16 11-24-2014 03:09 PM
Matching With the Beasts fang_gt86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 06-06-2014 01:33 PM
rev matching twoodcc BRZ First-Gen (2012+) — General Topics 86 11-06-2013 02:03 PM
Matching car seat Yruyur Scion FR-S / Toyota 86 GT86 General Forum 13 05-05-2013 10:26 AM
Rev Matching Selvedge Engine, Exhaust, Transmission 17 11-11-2012 06:48 PM
