Old 12-29-2014, 12:24 AM   #1
noogin
DELETE
noogin is offline   Reply With Quote
Old 12-29-2014, 06:07 AM   #2
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
http://www.ft86club.com/forums/showthread.php?t=62695
I know this isn't helpful for your issue, but this explains why you aren't getting a response.
2016 Camaro SS is offline   Reply With Quote
Old 12-29-2014, 08:39 AM   #3
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Fittings are going to be kit specific. But, they are regular old AN fittings you can order easily.
First I'd make sure they are the right sized fittings matching the threads. You may simply have to retap the threads and get the correct fitting. FA20club has been know to piece kits together, see above posters link. If you do reinstall the fitting a dab of anti seize will help.
Secondly don't apply locktite or teflon tape. If you need a quick temp fix a dab of black rtv should get you to the next oilchange though your gambling at that point.
The Following User Says Thank You to Kiske For This Useful Post:
noogin (12-29-2014)
Old 12-29-2014, 08:44 AM   #4
noogin
The Following User Says Thank You to noogin For This Useful Post:
2016 Camaro SS (12-29-2014)
Old 12-29-2014, 01:53 PM   #5
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Originally Posted by noogin View Post
Yea I realize all the issues with tony and fa20club and the prior owner who I bought the car from purchased the turbo kit way before shit hit the fan with them... Kit has been on for over a year and a half with no issues except now this. I had all the seals and welds checked and nothing alarming so far
Same here. I had some idling issues
Scalzo is offline   Reply With Quote
Old 12-30-2014, 06:11 PM   #6
noogin
So it looks like mine is #2 on this pic
After Kiske's comment, I read that using tape on AN fittings or any type of threadlock is a no-no, so I'm assuming replacing the fitting is the only valid option here? I'm starting to wonder if its the threading on the oil pan that might be causing it now
Old 12-30-2014, 06:49 PM   #7
myioz86
Drives: gt-86 2013
Noogin the an fittings dont need any tap on them they sealed seat to face.
you can buy small seat savers from any hydraulic shop put them between faces and tighten.
check its not leaking from between the shell and hose this is another leak point.
i make hoses in hyd shop all day so this is not an uncommon prob.
Thanks john
myioz86 is offline   Reply With Quote
Old 12-30-2014, 07:38 PM   #8
noogin
Thanks john
Seat savers? Not sure what that is... Like a crush washer?
Old 12-30-2014, 07:46 PM   #9
myioz86
Drives: gt-86 2013
Noogin yes they are a cone shape alloy crushable washer.
seal saver or seat saver they call them.
only 3 or 4 daollars to fix prob.
Thanks john
The Following User Says Thank You to myioz86 For This Useful Post:
noogin (12-30-2014)
MAP Aluminum Oil Pan / +1.5qt Capacity / Turbo Oil Return / Available now! MAPerformance Engine, Exhaust, Transmission 56 04-30-2024 04:54 PM
MAP Aluminum Oil Pan / +1.5qt Capacity / Turbo Oil Return / Available now! MAPerformance Engine, Exhaust, Bolt-Ons 25 03-03-2015 06:28 PM
Garrett Turbo Oil Restrictor Fitting Question rb6freak Forced Induction 2 01-07-2014 08:45 PM
fitting 17x9's with 255s, and fitting brake pads Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-29-2012 11:08 AM
