#15 |
Drives: Wrb 2014 limited brZ
Dino evidence isn't good enough?
#16 |
Drives: 2013 Subaru BRZ
this must be why my 200-300whp car has 1500 crank horsepower. always wondered how that worked. thanks for clearing that up for me!
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
| The Following 5 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post: | Fast_Freddy (01-01-2015), Jaden (01-06-2015), martinEZ (02-19-2015), Tristor (03-30-2018), ZDan (03-22-2015) |
#17 |
but yeah, this product sucks. clearly it screws with the MAF reading to lean out the stock tune a bit, or maybe throw the timing curve off by making the motor think it's under less load than it actually is. either way, you could accomplish whatever it is that they're trying to do with a tune, and then you'd have the bonus of the MAF sensor actually reading what it's supposed to read.
I feel like the car might try and learn around this too because of the feedback from the o2 sensor in closed loop...
| The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post: | Tristor (03-30-2018) |
#18 |
| The Following User Says Thank You to Koa For This Useful Post: | SomeoneWhoIsntMe (12-22-2014) |
#19 |
Given that there are already reports of mild detonation on stock cars, I can't imagine leaning out the stock AFR will be a good idea.
2022 BRZ Build 2013 FR-S Build |
| The Following 3 Users Say Thank You to DarkSunrise For This Useful Post: |
#20 |
Drives: 2013 asphalt scion FRS
Your absolutely right. Crank and wheel horsepower are totally the same thing....
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#21 |
I'm not disputing that wheel horsepower is less than crank horsepower, but you do realise that getting "2-3whp" from a 15 crank horsepower bump would correlate with a drivetrain loss between 80 and 87%, right? That seems slightly high to me.
| The Following 5 Users Say Thank You to SomeoneWhoIsntMe For This Useful Post: | Formula Vee (12-27-2014), Koa (12-22-2014), martinEZ (02-19-2015), Tristor (03-30-2018), ZDan (03-22-2015) |
#22 |
Lacking brains
Drives: frz
| The Following 15 Users Say Thank You to Model Citizen For This Useful Post: | BuBlake (12-29-2014), continuecrushing (12-26-2014), DocWalt (01-09-2015), finch1750 (01-24-2015), Flasher (01-28-2015), flippy (12-29-2014), Formula Vee (12-27-2014), Freeman (12-23-2014), Hyper4mance2k (03-04-2015), Jond63 (12-26-2014), mad_sb (12-29-2014), P@ul (12-27-2014), PA-86 (01-24-2015), raven1231 (01-06-2015), Tristor (03-30-2018) |
#23 |
Drives: 2015 Series.Blue
No, especially when it comes to small power changes that are under the percentage deviation of the dyno. This is why back to back runs are NEVER exactly the same. Also it doesn't prove much as there are other more nefarious ways to make a dyno look good (I'm not claiming they did this, just saying it's possible) |
#24 |
#25 |
Drives: 2014 Scion Fr-S
Crawford sent me the eco block for free to test, I have a 2014 frs, it has the trd intake, trd shift kit, flowmaster catback on it, i too was skeptical about what it did, Crawford told me if it was bad for the engine a check engine light should kick on, and if it did to go ahead and remove the block and send it back.
Anyways i put it on the car, and i have noticed a difference in the butt dyno, mainly from 3k-4k rpm in the dip it has improved throttle response in that range, i have noticed i can run 3rd gear at about 1000 rpm and hit the gas and the throttle response is smoother and no need to downshift. So far havent noticed any improvement to miles per gallon though, seems to have decreased about 1mpg, but its hard to tell the wind has been blowing 60mph everyday out here in the texas panhandle since i put it on. |
#26 | |
Thank you for this post and please keep us updated. It's easy for people to have doubts about this product but if it truly doesn't work with no problems, it would be on everyone's list for an easy mod. |
#27 | |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] Last edited by Apoc; 12-26-2014 at 05:31 PM. Reason: cleaned up |
#28 |
no its correct, i had put a spacer on my tundra's MAF sensor and it sent the ecu a code and CEL. so i dont think thats far fetched. Crawford knows more about FA20 engines than any other performance oriented company out there, so I would take their word for it, they never steered anyone wrong before.
Update I am on week 2 with the crawford eco block, still feel some power gain in the mid range, MPG is not seeing much yet, i am averaging about .2mpg above normal currently, but we'll see when I fuel up next tank. |
| Crawford AOS with FBM kit | whitefrs | Forced Induction | 40 | 10-14-2015 06:32 PM |
| WTB: Crawford BPB | v86 | Want-To-Buy Requests | 0 | 07-20-2014 09:59 PM |
| Crawford AOS | Thechow | Engine, Exhaust, Bolt-Ons | 2 | 06-23-2014 05:24 PM |
| FS Crawford AOS | whitefrs | Engine, Exhaust, Bolt-Ons | 4 | 07-04-2013 10:31 AM |
