| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
^^ Definitely spend the $20 on a battery tender. You'd be amazed how often those things come in handy!
#16 | |||
Drives: '14 Whiteout FR-S
*knock on wood*....
#17 | |
#18 |
Is there anyone you can ask to drive it every so often?
Make sure you put a fuel stabilizer in the tank! 2 years is a long time to let a car sit Nick C.
#19 |
Drives: scion fr-s
2 years is too long! Sell it!
#20 |
Having stored a couple of cars when deployed/posted overseas for extended periods I agree that most of the ideas already given are good.
Here is my thoughts (sorry for the repetition but just to have them all in one spot) Disconnect the battery if not worried about losing ecu settings. Had a buddy get mice in his engine compartment and chew some wires. The wires shorted and burnt half the car up before it was noticed. Use a tender on the disconnected battery. This way you reduce fire hazards but still keep the battery good. Use crappy tires and don't jack anything up. Sounds like that is your plan and it is a good one. Cover it. Again your plan. Do what ever you can to seal it all up. Critters seem to be the worst enemy to any long term stored car I have ever seen! Get somebody you trust to check it every once in a while. You didn't say where you are storing it but if somebody checks on a regular basis they can stop any problems before they get too bad. Make sure you have some insurance on it (or it is covered by where you are storing it). Just in case!
#21 | ||
Technically I can ask my dad to start it up every so often. But I've heard that starting it without running it decently hard may actually do more harm. I'm a bit wary of actually having him take it out for a rip because it won't have insurance. Quote:
I don't intend to put a cover on it, but my car will be kept in my garage. For the time being I intend to be back in July and intend to wash and wax it at that point. Thanks for the tips! Keep em coming! Also, any tips for when I fire it up again when I get back? My biggest worry is the fuel. I intend to fill the tank and add stabilizer. Should I just try to crank it? |
#22 | |
The longest one mine sat was just short of two years and it fired up second crank. Now mind you that was pre ecu days but still...
#23 |
Drives: 2015 Series.Blue
Ideally it would be good to fog the cylinders with some cylinder fogging oil, but this is difficult on the twins.
Critters, moisture, and overall dry rot is the biggest enemy here. Do you have an extended warranty? Cause you could have issues that arise from sitting that long that if you're paying out of pocket could make it wiser to simply sell it. |
#24 |
Drives: '15 BRZ series.Blue
Quite honestly, I would store it without fuel at all if possible. Siphon the tank, and pull the pump fuse. Crank it up to get residual fuel out of the lines, and then let her sit. That's jmho
| The Following User Says Thank You to cliff p. For This Useful Post: | roddy (12-18-2014) |
#25 | |
Nick C.
#26 | |
I am not talking day to day use. Always used it is stored cars before but with this engine you could be correct.
#27 |
Doesn't this pretty much guarantee condensation in the tank, followed by mold and all that good stuff?
#28 |
Drives: 2015 Subaru BRZ Series Blue
Look into "Star-Tron enzyme fuel treatment". We used stabil for years & it was always so/so.. We've had very good luck with this stuff as far as curing our enthenol issues while the machines sit aside for awhile. We use it in our cars, trucks, motorcycles, lawn mowers, chain saws, basically any gasoline engine. Claims to stabilize gas for up to 2 years.
http://instagram.com/cameronjones239
2015 Subaru BRZ Series Blue Build http://www.ft86club.com/forums/showt...09#post2002909 |
| Storing for a year | dragonwiddd | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 03-05-2014 08:12 AM |
| Storing Car For 9 Months | Touge86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 16 | 11-11-2013 10:21 AM |
| Storing my car | SmsAlSuwaidi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 06-22-2013 06:38 PM |
| Anyone storing their aftermarket parts until... | ScionFrsFan | Issues | Warranty | Recalls / TSB | 6 | 01-07-2013 07:01 PM |
| Storing an unused car? | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 02-21-2012 10:51 PM |
