Old 10-29-2014, 11:34 AM   #1
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
Question A long ignition time
I've had my 86 for about a year an 3 months now (30,000Km). The car takes more than usual to start. When i press on the ignition it feels like it wont start and then like 3-5 seconds later it starts. I have checked the battery, oil, and everything else. My car is an AT so there is no problem with me pressing the clutch.
Does anyone have a similar problem?
If so how did u fix it?
Thanks in Advance
AZOOZ_95 is offline   Reply With Quote
Old 10-30-2014, 08:04 AM   #2
ZZT86
ZZT86's Avatar
Drives: BR86
Poor fuel ? Timing issue, ignition coils maybe going bad ? Can't imagine a faulty or worn plug just yet.
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
AZOOZ_95 (10-30-2014)
Old 10-30-2014, 10:15 AM   #3
tobin
tobin's Avatar
Drives: '13 BRZ
Is it worse with an empty tank of gas than it is with a full tank of gas? Is it worse first thing in the morning when it has been sitting overnight?
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
Old 10-30-2014, 11:40 AM   #4
Imrac
Drives: 13 SWP BRZ Prem
Are you waiting a couple seconds with ignition on before cranking? Fuel pump needs to prime a bit in this car I found.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
The Following 2 Users Say Thank You to Imrac For This Useful Post:
AZOOZ_95 (10-30-2014), humfrz (10-30-2014)
Old 10-30-2014, 07:19 PM   #5
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
Actually no specific time just most of the times. For example today it never happened, but last week it was happening all the time.
Old 10-30-2014, 07:19 PM   #6
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
I always do
Old 12-17-2014, 05:35 AM   #7
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by AZOOZ_95 View Post
I always do
Hi!
Check main motor harness, located on the rear end of the engine near the battery. There are actually totally 3 harness located, you may check (or at least shake) all of them - i experienced the delay in starting my BRZ while i had problems with the biggest of 3 harness down there. But mine is stick.
Good luck!
Ondreiko is offline   Reply With Quote
The Following User Says Thank You to Ondreiko For This Useful Post:
AZOOZ_95 (12-17-2014)
Old 12-17-2014, 08:13 AM   #8
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
I have an AT with 11k miles and its all on how cold and how long its been since I have driven it.
rjgough95 is offline   Reply With Quote
Old 12-17-2014, 08:39 AM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
Mine has sat for a couple months a few times and started just fine.
Old 12-17-2014, 11:54 AM   #10
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
I actually found the issue. there was a short between the battery and the alternator
Thanks for the help guys
Old 12-17-2014, 12:48 PM   #11
JoeC
Drives: Subaru BRZ Limited
crazy. was there a worn wire or broken wire or a lose connection. what was the short?
JoeC is offline   Reply With Quote
Old 12-17-2014, 12:55 PM   #12
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
It was pretty worn out. I think its because of the weather here in KSA
Long time lurker new FR-S owner durdinn Scion FR-S / Toyota 86 GT86 General Forum 19 08-31-2014 12:03 PM
Been a long time.. New updates!! EPIKsung FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 08-28-2014 11:46 AM
Long time lurker, brand new owner SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 26 09-24-2013 08:43 PM
Ignition Taking Too Long? ggpaul Issues | Warranty | Recalls / TSB 10 06-18-2013 11:15 AM
How many of you plan to keep your FRS for a LONG time? frosty86 Scion FR-S / Toyota 86 GT86 General Forum 58 10-04-2012 05:53 PM
