Old 12-11-2014, 11:48 PM   #2507
xDanger_208x
xDanger_208x's Avatar
Drives:
Originally Posted by Gixxersixxerman View Post
Finally got to the dyno today, 417hp 312 lbft
Holy dog shit!!!
Specs please??!!??
xDanger_208x is offline   Reply With Quote
Old 12-12-2014, 12:28 AM   #2508
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Dude.
WTF.
Details.
Sellout is offline   Reply With Quote
Old 12-12-2014, 12:30 AM   #2509
xDanger_208x
Drives:
Originally Posted by Sellout View Post
Dude.
WTF.
Details.
That torque!!!
Old 12-12-2014, 01:10 AM   #2510
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I am jealous of your C38 and E85.....
Freeman is offline   Reply With Quote
Old 12-12-2014, 02:31 AM   #2511
SPCorBUST
SPCorBUST's Avatar
Good numbers! Right where they should be when dyno adjusted. What injectors?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 12-12-2014, 02:39 AM   #2512
SPCorBUST
SPCorBUST's Avatar
And which clutch?
Old 12-12-2014, 08:17 AM   #2513
Sellout
Mr. Cranky Pants
Sellout's Avatar
Injectors are listed underneath the video on youtube:
My 2013 Scion FRS putting 417hp to the hub with a Kraftwerks C38 running 17lbs of pressure. On E85. MXP UEL and overpipe, OEM front pipe, Dezod catback, 900cc deatschwerks injectors
Old 12-12-2014, 01:18 PM   #2514
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Originally Posted by SPCorBUST View Post
And which clutch?
Its a Automatic
Besides the high boost pulley setup, i have the MXP UEL and over pipe, OEM front pipe though it gutted itself, Dezod catback. DW 900CC injectors, Walbro 255 pump, and of course the flex fuel kit.. Thats a Moto-East setup.
otherwise the drive-train/line is stock, Running Motul oil and rear end lube, getting the Amsoil ATF for the trans, Church did say it may be slipping right at the top end, the car reads 7750 his dyno 7348. also had a bit of spike in the boost. from 15 or so to 17 at that spike, he said it may not be slipping just the ECU trying to tell the trans to shift.
Im running a bit rich up top, 10.3 so he said there is more if i wanted to lean it out, but im on the safe side so ill probably keep it there.. I haven't talked to Bill at delicious tuning yet to see what he thinks of everything
-Thomas
86SPEED is offline   Reply With Quote
Old 12-12-2014, 01:48 PM   #2515
D_Thissen
D_Thissen's Avatar
Awesome numbers! Let's see the dyno graph
Old 12-12-2014, 02:21 PM   #2516
86SPEED
86SPEED's Avatar
best i can do until i get a scan of the sheet
Old 12-12-2014, 08:34 PM   #2517
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Not too shabby at all. Those automatics seem to be holding up quite well for the level of power we're seeing through them.
Xero-Limit is offline   Reply With Quote
Old 12-12-2014, 10:12 PM   #2518
SPCorBUST
SPCorBUST's Avatar
in an automatic? wow, that's nice.
Old 12-12-2014, 10:46 PM   #2519
MidnightRunner
MidnightRunner's Avatar
Originally Posted by xDanger_208x View Post
Whoa nice job on the install. And sweet hvt camber plates too. Quick question:
*From what you saw with the washer bottle deleted, would there be any space issues fitting a standard 13 row oil cooler in place of your rotrex oil reservoir in that location?
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 12-12-2014, 10:48 PM   #2520
xDanger_208x
Drives:
I think you could. There's quite a bit of room over there.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
