Old 12-10-2014, 11:27 PM   #1
BRZlimited
BRZlimited's Avatar
Drives: 2013 Subaru BRZ limited
Wet engine bay?
So my battery has died on me three time in the past two months. I decided to buy a yellow top Optima since there ratings were amazing. Well, it is snowing out today but when I popped the hood open the original batter was all wet. The black plastic man under the battery was also. Should I be worried about this? I'm just worried that there gets a large enough amount of water on the battery to short it and create a cross current... If this is the case that could of been the issue with the old oem battery...
BRZlimited is offline   Reply With Quote
Old 12-10-2014, 11:40 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Lol. The engine bay isn't waterproof. Everything will be all wet. That's normal.
Stang70Fastback is offline   Reply With Quote
Old 12-11-2014, 12:13 AM   #3
BRZlimited
BRZlimited's Avatar
I know it's not water proof Haha, I just mean water and a battery don't usually mix well.
Old 12-11-2014, 01:29 PM   #4
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
I'm not an experienced car guy, but a cheap solution that comes to my mind is to take out the old battery, dry everything in the engine bay, put in a new battery....and take a 2-4 gallon freezer Ziploc bag and tape it over and around the battery. if it's sealed properly, water won't reach the connections.
Edit: Then again, it gets incredibly hot inside when the car is running.
carma143 is offline   Reply With Quote
Old 12-11-2014, 01:54 PM   #5
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
I sprayed down the engine bay with a cleaner and right after power washing while the car was on, then air gun dried. Nothing happens. Just cant soak it for a long while I guess.
Marcoscrdo is offline   Reply With Quote
Old 12-13-2014, 01:47 AM   #6
Poodles
Doesn't matter as electricity follows the path of least resistance.
In this case, it's not the water, but the connections that are the path of least resistance so it's fine.
FS: Password JDM Engine Covers and Gunmetal Engine Dress Up kit PrimeMotoring Engine, Exhaust, Bolt-Ons 10 11-26-2014 12:38 AM
FS: Password JDM Engine Covers and Gunmetal Engine Dress Up kit PrimeMotoring NY / NJ / CT / PA 2 10-23-2014 11:06 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
