| Software Tuning Discuss all software tuning topics. |
Drives: 86
Cannot Read Data Logging From OFT
I try to get data log for my MAF Scaling,
But OpenFlash Manager does not respond when I try to read log. Other features are all fine. Only data logging tab is the problem. How can I fix it???? Since I bought OFT, reading log data has not worked at all. I've tried administrator mode, win7, xp and other computers. Everything i've tried cannot solve it. ![]()
#2 |
Drives: 2013 FRS
Can't say I've seen that problem before. Do you have another computer that you an try? Doesn't matter if it's a desktop of laptop.
#3 |
Drives: 86
#4 |
Drives: 2014 Pearl BRZ Limited
32bit shouldn't make a difference. I run 64bit Win7 and have zero issues. Maybe try right-clicking the OFT manager icon, and 'running as administrator'.
*edit: nvm, just seen you tried that. hmm.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | Last edited by edeekeos; 07-08-2014 at 02:26 AM. |
#5 | |
Drives: FT86
plug oft into car and take new log this will erase old log and take new log in correct format. other than that out of ideas :-) |
#6 |
Drives: 2014 FR-S 6MT Whiteout
What if you try setting your computer to US/English. Maybe it's a localization problem?
#7 |
Drives: 2013 FRS
Are you sure you have a log file saved on the oft? Make sure you press Start and then Stop. At which time the OFT will give you a message saying that the csv file was saved.
#8 |
Looks like the computer is running in a Korean language, is that supported by OFT with the template?
| The Following User Says Thank You to wparsons For This Useful Post: | steve99 (07-09-2014) |
#9 |
Drives: Toyota 86
#10 |
Drives: 2013 Subaru BRZ limited 2.0l
Running Windows 8.1, Also cannot access data logging log,
![]() All other options work great. just would like to see the data logging log. I tried several times. |
#11 |
Drives: 2013 FRS
There is a formatting bug in the latest version of OF Manager. It only effects Windows 8.x users. It should be fixed within the next 24hrs. Until then you can access datalogging by just pressing the TAB button twice and then press Enter. Same thing has just clicking on the READ button which is now hidden.
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Spartiduck (12-08-2014) |
#13 |
Drives: 2013 FRS
hey guys
v1.15.1 is now downloadable: http://openflashtablet.com/Automotiv...ads/index.html Could you windows 8 guys confirm that the formatting issue is solved? Looks good on this end. cheers, shiv |
#14 | |
It installs in a new directory without the ability to install anywhere else. Formatting Looks good.
| Tags |
| data log, oft, open flash tablet |
| OFT Data Logging and Exhaust Leak | alexand3r | Software Tuning | 6 | 08-02-2019 07:02 PM |
| Data logging for noobs - OFT | Shad0ez | Software Tuning | 18 | 11-07-2016 07:20 PM |
| school me on data logging | fatoni | Tracking / Autocross / HPDE / Drifting | 11 | 01-09-2014 09:54 PM |
| Toyota Data Logging CAN for GT6 | Luckrider | Software Tuning | 1 | 11-23-2013 02:03 PM |
| Onboard Data Logging for XCross/Trackdays | brzmaybe | Tracking / Autocross / HPDE / Drifting | 16 | 06-15-2012 07:03 AM |
