| Member's Car Journals Car journals by our members. |
#29 |
Marine Electrician
Drives: Toyota TRD86, 2014
Your build is comming along great!
Great to see the toms on tha car, I have been on the fence about ordering either clear or red ![]() Cheers
My Toyota TRD86 can be found here:
http://www.ft86club.com/forums/showthread.php?t=63303 |
| The Following User Says Thank You to Teclis For This Useful Post: | jvargasj88 (07-03-2014) |
#30 |
Drives: Toyota 86
Beautiful 86 sir! And looks like Autokozmetix has everything for the 86. Excited!!!
| The Following User Says Thank You to PatAngeles For This Useful Post: | jvargasj88 (06-27-2015) |
#31 |
Drives: 2013 Toyota 86 TRD - Galaxy Blue
K&N High Flow Air Filter
Purchased from: eBay USA Installed in: Autokozmetix I decided to upgrade my air filter instead of purchasing an air intake. Reviews online indicated that most of the air intakes available in the market today, revealed through dyno tests, that the HP gain is almost the same as that of aftermarket air filters (which is also significantly cheeper) due to the stock housing already designed as a cold air intake. In fact, some aftermarket air intakes proved to reduce HP (such as AirRaid lowering HP by 16) ![]() I chose K&N since it achieves one of the highest HP gains (+5.7WHP) for an air filter on the 86, as shown by DSport Magazine's Dyno Test [ame="https://www.youtube.com/watch?v=3DbkmThHYMs"]2013 Scion FR-S Intake: K&N Replacement Filter Dyno Test - YouTube[/ame] ![]() ![]() ![]() Since it is an oiled filter, there is a risk of affecting the MAS. Based on the reviews, it should be fine out of the box. Upon cleaning it, you just need to make sure that you don't over oil it, the recommended amount is 0.68 oz (20 ml). Looking at the description on the box, it usually takes up to 50,000 miles until it needs cleaning (depending on driving conditions). The installation was really quick, it probably didn't take more than a minute. Compared to the stock air filter, the K&N filter is just a bit louder but not as aggressive sounding as having an air intake. You also can't feel much of the power gain since it only increased by 5.7WHP, but it still makes a difference. Last edited by jvargasj88; 06-27-2015 at 09:12 AM. |
#32 |
TRD Emblem (Type B)
Purchased from: Tom's and TRD Shop HK Installed in: Autokozmetix Got the Type B TRD Emblem, apparently it was designed specifically for the 86. ![]() ![]()
#33 |
TRD Sound Changer (Blue)
Purchased from: Tom's and TRD Shop HK Installed in: Autokozmetix ![]() ![]() ![]() ![]() * Review to follow * Last edited by jvargasj88; 06-27-2015 at 09:09 AM. |
#34 |
Beatsonic Shark-Fin Antenna (Blue)
#35 |
TRD Fender Extension
Purchased and Installed at: Autokozmetix ![]() ![]() ![]() ![]() Before: ![]() ![]() After: ![]() ![]() *Review and more pictures to follow* Last edited by jvargasj88; 06-27-2015 at 07:45 AM. |
| The Following User Says Thank You to jvargasj88 For This Useful Post: | AG3NT_5CARFAC3 (07-22-2015) |
#36 |
Marine Electrician
Nice work!
Cheers from a fellow Galaxy blue TRD 86
| The Following User Says Thank You to Teclis For This Useful Post: | jvargasj88 (06-28-2015) |
#38 |
Drives: 2015 Scion FR-S
Nice set up paps!
| Tags |
| blue, trd |
| Laika's Galaxy Blue BRZ OEM+ | Laika | Member's Car Journals | 59 | 11-12-2013 04:04 AM |
| WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents | BlueLeader | Exterior Parts (Aero, Lighting, Etc.) | 0 | 03-18-2013 03:55 PM |
| Galaxy Blue - NZ | diss7 | AUSTRALIA | 5 | 09-25-2012 07:51 AM |
| Sonic Blue 86, Galaxy Blue deleted? | 450hp/tonne | AUSTRALIA | 14 | 09-01-2012 08:10 PM |
| Galaxy Blue VINs? | dorkymork | BRZ First-Gen (2012+) — General Topics | 49 | 06-02-2012 10:55 PM |
