Old 11-29-2014, 10:12 PM   #1
J_kennington
Drives: 2013 asphalt scion FRS
winjet led wiring to factory led fog strip?
So, my question is:
I have the factory led strip fog lights. Which has the strips on ea each side, a controller located under the dash, and a switch on the dash. I recently acquired a pair of winjet head lights and was thinking I could power the boomerangs with the fogs. So they run the same sequences (full on-head light off, dim head light on). Would I need to tap the winjets before the controller or after? Do the winjets have a built in controller?
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 12-02-2014, 07:04 PM   #2
ScorpionOzzy
Drives: Scion FR-S
That actually doesn't seem like a bad idea. I don't know how the winjets are wired, but I would just run the positive for the LED strip on the winjets, and tap into the positive for the led strip below it. Ground on the factory headlight connector. Should be pretty simple.
ScorpionOzzy is offline   Reply With Quote
Using factory wiring for aftermarket fog light kits Wizardhat Cosmetic Modification (Interior/Exterior/Lighting) 8 12-05-2021 05:05 PM
HELP: WINJET Headlight LED strip INOP 1SIKFRS Cosmetic Modification (Interior/Exterior/Lighting) 10 09-02-2014 12:28 AM
Wiring a sub to the factory HU cfusionpm Electronics | Audio | NAV | Infotainment 8 05-04-2013 10:54 PM
Factory head unit wiring help please. jabbajaw99 Electronics | Audio | NAV | Infotainment 2 03-24-2013 07:09 PM
alarm wiring help? (using factory remote) luv85 Scion FR-S / Toyota 86 GT86 General Forum 0 12-28-2012 08:59 AM
