Old 11-30-2014, 02:54 AM   #43
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Originally Posted by cdrazic93 View Post
R154!!!!
5speed?! Blasphemy in the 21st century!!!
Certainly, R154 is another great budget conscience solution if you don't mind being a 5spd.
hmong337 is offline   Reply With Quote
The Following User Says Thank You to hmong337 For This Useful Post:
cdrazic93 (11-30-2014)
Old 11-30-2014, 03:16 AM   #44
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I feel this car should have been a 5.5speed. Third and 4th are practically the same damn gear. Unfortunately, with such shit power output, 5 gears would make the car feel even slower.
slicktop is offline   Reply With Quote
Old 11-30-2014, 03:32 AM   #45
mike the snake
You didn't look at this link. This one's for a six speed BMW gearbox that does have reverse. I think it's an M5 box
Originally Posted by Reaper View Post
I replied to this in the other thread. No reverse, no real first gear, no clutch disk/flywheel combo that fits our car.
The Following User Says Thank You to mike the snake For This Useful Post:
Reaper (11-30-2014)
Old 11-30-2014, 08:29 AM   #46
acro
Drives: GT-86
To what? I just replaced a transmission in a car with 350whp last week and 3 of my local buddies just did ones in their stock frs' this summer. Stock power is breaking them too. I just don't like my options right now of either 20k $ for a sequential or 8+k $ for a transmission that isn't even made anymore.
Seriously what are they doing to break the tranny with stock power
I know of people abusing the cars regularly on track without issues
acro is offline   Reply With Quote
The Following User Says Thank You to acro For This Useful Post:
raven1231 (11-30-2014)
Old 11-30-2014, 11:09 AM   #47
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Cryo treating is an option, as well as a tranny cooler for the manual trans like the coolers they have for the auto.
How the hell would you make a bellhousing for that?
Originally Posted by mike the snake View Post
Old 11-30-2014, 11:09 AM   #48
Reaper
Reaper's Avatar
Drives: violent
Has anybody tried strengthening the stock gearbox though metal treating processes? Seems like a viable cost effective power holding solution. Disassemble the gearbox, send the gears to treating then reassemble. Mind you, 400whp and whatever tq is all I would ever want out of this car. But metal treating could be worth a shot. Anything more than 450hp in this car and you're just better off buying something different and beastly.
Already tried it.
Old 11-30-2014, 11:10 AM   #49
Reaper
Reaper's Avatar
Drives: violent
Already tried it.
Old 11-30-2014, 11:11 AM   #50
Reaper
Reaper's Avatar
Drives: violent
One of them is on stock tires too. Syncros failed.
Old 11-30-2014, 12:36 PM   #51
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
There are so many factors to consider, you can't just throw out an obscure number and say that is the failing point. Heat and oil starvation are ultimately the biggest enemies, which has more to do with the tune and how you drive it..
You could probably make a single dyno pull at 500whp on pump gas and not fail, and you could probably drive the car balls to the wall 24/7 at 250whp and throw a rod. Hell, people have blown completely stock engines..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
slicktop (12-02-2014)
Old 11-30-2014, 01:29 PM   #52
Cal3000
Drives: Panda FR-S
It's probably a hit or miss. I've been pushing hard with FI for over 50,000 miles.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following 2 Users Say Thank You to Cal3000 For This Useful Post:
hmong337 (11-30-2014), slicktop (12-01-2014)
Old 11-30-2014, 02:58 PM   #53
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Hm. Fluid cooler & does anyone want to make a larger trans fluid pan for the manual?
Old 11-30-2014, 04:30 PM   #54
mike the snake
Manual transmissions generally don't have pans like most autos.
A cooler and pump, and maybe an external tank to hold extra oil would be the way to go I would think.
Old 12-01-2014, 12:30 AM   #55
Reaper
Reaper's Avatar
Drives: violent
Do you know what a manual transmission looks like?
I am currently running an external cooler.
Old 12-01-2014, 09:59 PM   #56
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
I believe the fa20T is a bit tougher from the heavier weighted internals. FA20 pistons coming in at 311.2g, rods being 346.8g and cap at 112.3g.
The fa20T pistons being 360g, rods coming in at 370.9g and cap at 120.7g. As per Tomei not my own observations.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
The Following 4 Users Say Thank You to Grip Ronin For This Useful Post:
10Stars (12-02-2014), Bonburner (04-08-2015), GT86_PRAGUE (12-12-2014), Kronos (12-02-2014)
WTB FA20 Stock Cross Want-To-Buy Requests 22 08-19-2014 03:59 PM
WTB FA20 Stock Cross Want-To-Buy Requests 1 08-01-2014 07:47 PM
Stock FA20/trans, never modified 9k miles ATM - April/May slicktop Engine, Exhaust, Bolt-Ons 2 02-24-2014 08:44 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
Stock AISSIN Transmission Power Capacity Don@Accelerated Forced Induction 37 07-03-2013 11:15 PM
