Old 11-24-2014, 04:40 PM   #15
fang_gt86
FR Noob
fang_gt86's Avatar
Originally Posted by serialk11r View Post
Instead of a shaft (100% conversion efficiency), you are using a pump and a turbine which has considerable losses through flow viscosity and "leakage" at the pump and turbine. It would be better to use an electric generator and motor pair which would have maybe 85% efficiency.
Looks like a typical "gear pump" gives about 85% efficiency with the right design like fluid viscosity, clearance between internal components, friction between mating components, etc..
http://web.mit.edu/2.972/www/report-gear_pump.html
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 11-24-2014, 05:52 PM   #16
Tareim
Drives: 2013 Subaru BRZ
surely a dc motored centrifugal turbo/supercharger would be more efficient than this setup?
essentially like what mercedes f1 is doing but without the connecting shaft between the compressor and turbine to mimic your configuration rather than hydraulic
Tareim is offline   Reply With Quote
Old 11-24-2014, 06:21 PM   #17
serialk11r
Drives: '06 AM V8V Coupe
Now what about the driven side?
Old 11-24-2014, 09:15 PM   #18
fang_gt86
FR Noob
fang_gt86's Avatar
Hard to say what the efficiency rate is for a typical automotive radial flow turbine. If I understand correctly (which is unlikely LOl), I think the efficiency will vary based on its application.
http://www.hindawi.com/journals/ijrm/2012/589720/
Old 11-24-2014, 09:28 PM   #19
fang_gt86
FR Noob
fang_gt86's Avatar
This is basically a hybrid system on steroids. Wonder if they'll introduce it into their production cars.
Old 11-24-2014, 11:00 PM   #20
stugray
Drives: 2013 GBS BRZ Limited
http://www.cpowert.com/Products/TIGERS
Old 11-25-2014, 07:37 AM   #21
Tareim
I'm sure it'd come through at some point it's just when and how much
Old 11-25-2014, 08:09 AM   #22
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
The hydraulic fluid is going to get stupidly hot. I think that would be the hardest thing to solve: finding a fluid that can live in that environment.
pushrod is offline   Reply With Quote
Old 11-25-2014, 09:22 AM   #23
stugray
So.... how do turbos currently get lubricated? - plain old engine oil?
The Following User Says Thank You to stugray For This Useful Post:
pushrod (11-25-2014)
Old 11-25-2014, 10:14 AM   #24
Tareim
That's correct for the ones I've seen
Sent from my OnePlus One using Tapatalk
Old 11-25-2014, 01:41 PM   #25
pushrod
Benched 86lb
pushrod's Avatar
That's right. But in this case, it's supposed to be a working fluid. Cooling oil circulates by, picks up some heat, and moves on through a cooling process. In this case, it's being pressurized, heated, and moved, all without any cooling. Introducing cooling would cut into the efficiency of this system, and not by a small amount.
Old 11-25-2014, 01:53 PM   #26
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Didnt mercedes do this (pull their turbo in half) in their F1?
Old 11-25-2014, 02:15 PM   #27
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yes but with a mechanical shaft connecting the two turbines, not a hydraulic coupling like OP is proposing.
From a quick and dirty standpoint if you wanted to try splitting the turbo on a front mounted boxer like this it'd probably be best to have the exhaust turbine in the front of the engine mounted low where our exhaust manifold already is with a shaft vertical to an intake turbine in line with our stock intake manifold.
For our cars you'd have to chop up and lengthen the front end to get the space (and the associated exhaust plumbing wouldn't be pretty) but in the process can probably improve the airflow to reduce the cooling issues high powered toyobaru's have.
Old 11-25-2014, 03:38 PM   #28
serialk11r
Hydraulic coupling is extremely lossy and should be avoided whenever possible. A turbo can be transmitting 40hp in bigger engines, and for most applications at least 10.
Mercedes did not split their turbo in half, they kept the shaft because boost is constantly being used so it's better to have more efficiency under boost than less wasted power off boost. On a road car it makes more sense to have a fully electric system because a road car is barely ever on full throttle, but the electrical system needs to be super beefy to transmit that kind of power and so it's probably better to just compromise somewhere and keep a mechanical connection.
Hydraulic Hand Brake? Gillams Scion FR-S / Toyota 86 GT86 General Forum 2 09-18-2014 04:47 PM
AVO Turbo Front Mount Intercooler (BRAND NEW) tamsau Engine, Exhaust, Bolt-Ons 1 06-18-2014 10:53 PM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 01:37 AM
OEM hydraulic hood props ML Cosmetic Modification (Interior/Exterior/Lighting) 4 07-23-2013 09:24 AM
