Old 11-21-2014, 06:16 PM   #1
AlanKent
Dead battery.
So it has been cold here in Colorado and I think it caused my battery to die. I have another vehicle that I drive if there is snow on the ground, but today was nice so I decided to take the BRZ out. It was only about a week ago that I last drove it. Is this typical? Should I be shopping for an Optima battery to replace the factory one? Plus, my dash no longer says what gear I am in (manual trans). How do I get it to do that again? Thanks in advance!
AlanKent is offline   Reply With Quote
Old 11-21-2014, 06:47 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Your battery shouldn't be dead after a week no matter how cold it is. The car also isn't old enough for it to just need to be replaced. Though I suppose it could be a defective battery. I'd be more inclined to think you accidentally left a light on.
Yet another reason I'm going all-LEDs soon :P
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
JohnJuan (11-22-2014)
Old 11-21-2014, 07:39 PM   #3
AlanKent
That's the thing. I couldn't find a light that was left on. As long as it is not a known problem I won't worry about it unless it happens again. Anyone have ideas on how to restore the gear indicator?
Old 11-21-2014, 07:46 PM   #4
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Mine does the same. the battery is weak.
ntron1 is offline   Reply With Quote
Old 11-21-2014, 08:37 PM   #5
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
Mine sat outside in co also during the last snow and fired up just fine after a week of sitting
Digitalanalog is offline   Reply With Quote
Old 11-21-2014, 09:04 PM   #6
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
http:// https://www.google.com/url?q...yvw8WrdD9QD1Fg]
Edit: Desktop version:
[ame="https://www.youtube.com/watch?v=EL50fh9-_9A"]2013 BRZ FRS: How To Set Shift Light and More HD - YouTube[/ame]
carma143 is offline   Reply With Quote
Old 11-22-2014, 04:44 AM   #7
AlanKent
Thanks!
Old 11-22-2014, 07:55 AM   #8
Foobar
SLO NO MO
Foobar's Avatar
Stock battery is hit or miss. Several of us have seen it lose charge quickly.
I've got an Optima yellow top now.
Old 11-22-2014, 12:41 PM   #9
navanodd
Drives: 2013 BRZ Sport-tech WRB
The car will shut off any lights accidentally left on after 20 mins.
navanodd is offline   Reply With Quote
Old 11-22-2014, 01:29 PM   #10
ckkone
ckkone's Avatar
Drives: 2013 BRZ Limited
Really, why do you need an Internet post to help you determine if your battery is bad. Go to an auto parts store and get it tested.
ckkone is offline   Reply With Quote
The Following User Says Thank You to ckkone For This Useful Post:
brzadrian (11-23-2014)
Old 11-22-2014, 01:40 PM   #11
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
did you arm your car with alarm? but if you have warranty, you should always go back to dealer to claim it.
Speed2th is offline   Reply With Quote
Old 11-22-2014, 06:57 PM   #12
smotonaga
smotonaga's Avatar
Drives: Subaru BRZ Series.Blue
When the battery is disconnected, the Gear Indicator and Rev light/indicator will go back to default, which is off. Fortunately your radio stations will stay the same. But for your situation its a dead battery rather than a disconnect. There might be a parasitic draw somewhere like a light left on somewhere that will drain your battery. Anything above 50mA (0.050A) is too high of a draw with car off.
smotonaga is offline   Reply With Quote
Old 11-22-2014, 11:04 PM   #13
AlanKent
It was to see if it was a common problem and whether or not I should replace it with an after market one. Not all batteries are built the same. Some factory batteries are down right cheap.
Old 11-22-2014, 11:43 PM   #14
Foobar
SLO NO MO
Foobar's Avatar
My 13 BRZ doesn't do that. I left the dome light on far hours once.
Dead battery; starts up in limp mode kilrb Issues | Warranty | Recalls / TSB 15 01-04-2018 03:54 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Is there any know that how to open the truck when the battery is dead?????? wilson0326 Scion FR-S / Toyota 86 GT86 General Forum 31 07-06-2013 10:24 PM
Dead Battery BUT Honk Horn and it Turns on Car ScionFR-S Issues | Warranty | Recalls / TSB 9 06-11-2013 03:47 PM
Ignorance and a dead battery Red John Issues | Warranty | Recalls / TSB 9 03-02-2013 02:29 PM
