Old 11-15-2014, 09:47 PM   #1
ptrsracing
Drives: 2014 frs monogram white
smart key exterior door handle
Does anyone know how to remove the exterior door handle with touch unlock? I tried to remove it today but no luck. searched the forum there is only guides for regular door handles.
ptrsracing is offline   Reply With Quote
Old 11-17-2014, 06:22 PM   #2
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
I tried the same thing for a long time... No luck. I ended up taping it off when I had to paint.
Don't let anyone tell you it's as easy as sliding it forward... It's not.
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 11-18-2014, 12:28 AM   #3
navanodd
Drives: 2013 BRZ Sport-tech WRB
I haven't myself, but this is what I use whenever I need to figure out how to get anything on the car apart:
http://www.ft86club.com/forums/showthread.php?t=35279
Its a little tricky to get opened up at first because it's Japanese, but the actual instructions and categories are all English once the directory is open.
navanodd is offline   Reply With Quote
Old 11-21-2014, 01:35 PM   #4
ptrsracing
link is dead ..
Old 11-21-2014, 01:35 PM   #5
ptrsracing
anyone know how? i need to remove it for vinyl wrapping
Old 11-21-2014, 05:25 PM   #6
onefitz
Drives: 13 GBS BRZ
So the service manual shows that there's a torx screw on the inside of the door that you have to remove to pull off the cover where the lock would normally be. Once you do that you:
" Removal of the front door outside handle ASSY LH
(1) Pull the front door outside handle ASSY LH towards the back of the vehicle, and release the front door outside handle frame SUB-ASSY LH.
(2) Pull the front door outside handle ASSY LH towards you, and remove it from the front door outside handle frame LH"
onefitz is offline   Reply With Quote
Old 11-22-2014, 01:19 AM   #7
ptrsracing
this is for the non smart key access isnt it?
Interior Door Handle Help effty_ac DIY (Do-It-Yourself) Guides 4 12-28-2013 10:04 PM
Exterior Door Handle Removal NYCsubaruBRZ DIY (Do-It-Yourself) Guides 1 11-16-2013 01:47 AM
Door handle replacement cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 5 07-18-2013 04:07 PM
Door handle replacement cslntuee DIY (Do-It-Yourself) Guides 1 07-17-2013 10:52 PM
Door Handle cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 11 03-24-2013 03:49 AM
