Old 11-18-2014, 03:52 PM   #15
Koa
Originally Posted by Cdub998 View Post
Well i just finished mine. I have a little bit of adjustment on the pedal still but man is it better. There is an engagement point now. It is so much less vague. Thanks for figuring this out. I wanted to add a few more part numbers for everyone.
I got my part from autozone
part # 90028
Subaru part # 30620-aa041
Still 3/4 and fit perfectly
Can you provide a pic of the box? I'm pulling up nothing at Autozone's website parts catalog for #90028. Am I missing something?
Old 11-18-2014, 03:54 PM   #16
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
part # 90028
hmm...I tried calling the one near me, and *shocker* the guy had no idea (and no, I didnt say what I was using it for-just tried to have him look up the number.) The 90028 pulled up nothing, and the oem # just came up at almost $100.
Trying another one haha
Old 11-18-2014, 04:02 PM   #17
continuecrushing
Yeah, I got nothing too.
I think that part number might be wrong, the OEM part number WE WANT FOR UPGRADE is 30620aa111
So, I called autozone again, and gave the proper OEM# (30620aa111-which is the 3/4 one) and they pulled it up as $23.99
autozone Part # 52337 or alternate # LSC337
Okay, here is the AUTOZONE BREAKDOWN:
The correct part to order is "900061"-CLICK for Link Which is $31.99 (11/18/14)
Part #52337/alternate #LSC337 will fit. However, the mounting point for the clutch line is oriented differently, so this is not ideal.
The Following User Says Thank You to continuecrushing For This Useful Post:
Ultramaroon (11-18-2014)
Old 11-18-2014, 04:27 PM   #18
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
I grabbed the linked one below. Not installed yet.
http://www.autozone.com/drivetrain/c...er/383444_0_0/
Edit: So if you look @ vehicle fitment on both links... The one I posted is for 2007 & newer the other one posted is for 2005 & older. I wonder what the differences are...
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 11-18-2014, 04:47 PM   #19
continuecrushing
haha. When I called the first time, the guy came up with that part number/price. I guess we'll see lol
Old 11-18-2014, 04:58 PM   #20
Phantobe
Phantobe's Avatar
I think it could be wrong...
http://parts.subaru.com/p/Subaru_200...0620AA042.html
Take a look, different PN & matches with vehicle fitment on Autozone. I'll take a closer look when I'm home...
Old 11-18-2014, 06:50 PM   #21
I will edit my posts once I pickup/install/confirm fitment size
That's the wrong one, just like the one I installed but didn't feel like exchanging. It works just fine if you mount the banjo fitting outside of the guide in the casting. Not optimal because it "might" vibrate loose. I've been watching mine. No way is it going anywhere.
Get the right one. @Phantobe has it. Autozone P/N 900061
Old 11-18-2014, 07:04 PM   #22
The rough casting is different. The older one is actually a little shorter (no problem for us) and the guide for the banjo fitting is perpendicular to the centerline of the cylinder.
Yours, the correct one, has a guide oriented at 45° to the cylinder.
Old 11-18-2014, 08:03 PM   #23
Phantobe
Phantobe's Avatar
Sweeeeeet...
Are the washers also referred to as "brake line washers"?
http://www.autozone.com/brake-system...er/773866_0_0/
Was gonna grab those instead of OEM.
Old 11-18-2014, 08:41 PM   #24
Sweeeeeet...
Yup, 10 mm is what you want.
Old 11-19-2014, 08:07 AM   #25
Cdub998
Cdub998's Avatar
Drives: 2014 BRZ
Sorry guys. it came in a bag with the 90028 number on it. Let me see if I can still find the bag today. Its a duralast part if that helps. When I went I gave them the oem 3062aa111 and that is what they gave me.
Cdub998 is offline   Reply With Quote
Old 11-19-2014, 12:57 PM   #26
continuecrushing
if you gave them the 3062aa111 number, they probably gave you the "wrong" slave. IE, the fitting on it faces a slightly different way. Still fits though, but the line could have extra stress on it since it points the banjo fitting further away.
I installed mine last night, everything went on just fine. Since I'm running the "wrong" one, I might remove the bracket between the hardline and the rubber line and bend the metal hardline so its a little closer to the slave. Or just replace the whole line entirely with an aftermarket one.
Old 11-19-2014, 05:18 PM   #27
37
degrees
37's Avatar
Drives: 6MT BRZ
You could install the banjo like the photo I posted here in @Ultramaroon's original thread. It's not ideal but would work to keep the banjo from loosening the bolt. I believe @Ultramaroon is currently using this as a workaround with his slave.
37 is offline   Reply With Quote
Old 11-20-2014, 01:42 PM   #28
You are correct, sir. It's holding up perfectly but I'm feeling a little guilty about half-assing the photos. I'll replace the replacement with the correct one and update the photos in the OP soon.
Edit: I haven't replaced it. Works fine. I'll get the correct one when this one is no longer serviceable.
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 07:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 09:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 11:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 02:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 06:32 PM
