#15 | |
Drives: Wrb brz
#16 |
#17 |
Drives: Wrb brz
#18 |
#19 |
What kind of pads were you running? The AP Racing "endurance" kit is a lot of brake for a 2700lb car. I've seen bigger/faster cars function with less on a track...the caveat is they were using full race compound pads.
#21 |
Drives: '13 Denali, '15 Volt, soon a BRZ?
Who is Element and what does that have to do with Brembo Race System or Club Racing brake upgrades?
#22 |
Drives: Wrb brz
It's a rocket bunny car with a similar setup to element's car. Built block, sparco EVO seats, gtx 2867 turbo, Cusco diff, rear seat delete, Tarmac 2 coilovers, AP sprint BBK kit, apr wing, custom designed aero, 5 point harness, harness bar, and some small susoension components.
#23 | |
Small gains in lap times result in exponential increases in wear and heat. |
#24 |
Well, Race Technologies got a call!
p/n left xb1.e7.23 and right xb1.e7.24. Out of the Brembo catalog these have an msrp of $850 each. These are racing, or more correctly TRACK DAY, calipers as the cost savings are in the production of 2-piece castings vs 1-piece forges or billets and Fe inserts instead of Ti. For reference, the cheaper of the two F3 4 piston calipers msrp at around $950. The biggest downside is the lack of any bridging which will reduce the calipers torsional stiffness vs with a bridge. The question is it enough to have any performance impact; The AP kits by Essex only have a single bar bridge. Info is top of pg 24 in this doc: http://www.brembo.com/it/Auto/Racing...MBO_RACING.pdf Last edited by Hoosier Daddy; 11-17-2014 at 06:37 PM. |
| The Following User Says Thank You to Hoosier Daddy For This Useful Post: | DAEMANO (11-18-2014) |
#25 | |
![]() The lack of a bridge is concerning but I don't know enough to say if it will be felt. Maybe the caliper is just that strong. With the piston sizes listed in the catalog and 355mm discs, you'll have a pretty decent frontward shift in brake bias. I'd go smaller than 355 if you could, or add a rear kit. But assuming you're running hoosiers, it may be an acceptable tradeoff to get the fade resistance you need. - Andy |
#26 | |
Rear upgrade easily solves the balance problem. The two piston rears available in the Brembo catalog have the same mounting offsets as the production 2 pistons that are on the WRX Stis (28 mm) - choose your bore (36, 38, 40, and 42 mm). They are less than $300 each. And rotors are cheap! BTW, who builds a 'race car' without a bias adjuster? EDIT: the rears are 500 each... Last edited by Hoosier Daddy; 11-18-2014 at 01:40 PM. |
#27 | |
#28 | |
![]() Seems like you've got a good background already with brakes and specifically brembo. Please keep us posted on what you end up with! - Andy |
| Brembo Big Brake Kits and Fluid! GT/GT-R/Club Race | Corner3garage | Brakes, Suspension, Chassis | 106 | 04-24-2015 02:36 PM |
| STI Brembo HELP ~ | Trap63 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 08-02-2013 07:59 PM |
| 86 to Race inaugural Moder Sports Car Race | 000 Racing | AUSTRALIA | 4 | 05-23-2013 07:22 PM |
| No Race Track Seats in Race Car Drivers Every Day Cars..!! | JohnnyNight | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 10-16-2012 05:42 PM |
| Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 329 | 10-16-2011 09:51 PM |
