Old 11-16-2014, 06:25 PM   #15
Fastbrz
Drives: Wrb brz
355x32 is what was determined to be the equilibrium point for this car with stock power in a race.
Short hot lapping sessions will not be as hard on the brakes as a race, and street/canyoning (short of something like Pike's Peak) will not be as hard on the brakes either.
As a data point, the AP Racing Endurance kit is *not* enough braking capacity for me to run a 20 lap spring race with street tires on a stock car... How many people here are actually racing?
I'm actually working on a functional rocket bunny kit. unfortunately I went with the AP Sprint bbk kit
Fastbrz is offline   Reply With Quote
Old 11-16-2014, 07:23 PM   #16
CSG Mike
CSG Mike's Avatar
Those words are mutually exclusive...
Old 11-17-2014, 12:57 AM   #17
Fastbrz
Drives: Wrb brz
Element has a functional wide body car.
Old 11-17-2014, 02:31 AM   #18
CSG Mike
CSG Mike's Avatar
Widebody =/= rocket bunny. Are you doing rocket bunny or Element's setup?
Old 11-17-2014, 07:20 AM   #19
FRSRAVEN
What kind of pads were you running? The AP Racing "endurance" kit is a lot of brake for a 2700lb car. I've seen bigger/faster cars function with less on a track...the caveat is they were using full race compound pads.
FRSRAVEN is offline   Reply With Quote
Old 11-17-2014, 09:25 AM   #20
Racecomp Engineering
Agreed.
- Andy
CSG Mike (11-17-2014)
Old 11-17-2014, 10:30 AM   #21
Hoosier Daddy
Drives: '13 Denali, '15 Volt, soon a BRZ?
Who is Element and what does that have to do with Brembo Race System or Club Racing brake upgrades?
Hoosier Daddy is offline   Reply With Quote
Old 11-17-2014, 01:08 PM   #22
Fastbrz
Drives: Wrb brz
It's a rocket bunny car with a similar setup to element's car. Built block, sparco EVO seats, gtx 2867 turbo, Cusco diff, rear seat delete, Tarmac 2 coilovers, AP sprint BBK kit, apr wing, custom designed aero, 5 point harness, harness bar, and some small susoension components.
Old 11-17-2014, 03:01 PM   #23
CSG Mike
CSG Mike's Avatar
We're using race compounds.
Small gains in lap times result in exponential increases in wear and heat.
Old 11-17-2014, 04:45 PM   #24
Hoosier Daddy
Well, Race Technologies got a call!
p/n left xb1.e7.23 and right xb1.e7.24.
Out of the Brembo catalog these have an msrp of $850 each. These are racing, or more correctly TRACK DAY, calipers as the cost savings are in the production of 2-piece castings vs 1-piece forges or billets and Fe inserts instead of Ti. For reference, the cheaper of the two F3 4 piston calipers msrp at around $950. The biggest downside is the lack of any bridging which will reduce the calipers torsional stiffness vs with a bridge. The question is it enough to have any performance impact; The AP kits by Essex only have a single bar bridge.
Info is top of pg 24 in this doc: http://www.brembo.com/it/Auto/Racing...MBO_RACING.pdf
The Following User Says Thank You to Hoosier Daddy For This Useful Post:
DAEMANO (11-18-2014)
Old 11-18-2014, 11:26 AM   #25
That's a fun catalog to look through.
The lack of a bridge is concerning but I don't know enough to say if it will be felt. Maybe the caliper is just that strong.
With the piston sizes listed in the catalog and 355mm discs, you'll have a pretty decent frontward shift in brake bias. I'd go smaller than 355 if you could, or add a rear kit. But assuming you're running hoosiers, it may be an acceptable tradeoff to get the fade resistance you need.
- Andy
Old 11-18-2014, 01:17 PM   #26
Hoosier Daddy
- Andy
It's only a concern if it does have significant deflection. I have history with the old 4 and 6 piston NASCAR intermediate Brembo calipers that had no bridge...The only problem we ever had was a clip failure one time where the pads flew out on a pit stop - same issue could happen with these Club Racing kits. I bet Hayworth might have some data on the old NASCAR intermediate calipers vs the new bridged versions. I have seen test data on their RC calipers, so it could be out there... Might not be 1:1 comparison with the Club Racing calipers but could be a rough way to gauge the importance.
Rear upgrade easily solves the balance problem. The two piston rears available in the Brembo catalog have the same mounting offsets as the production 2 pistons that are on the WRX Stis (28 mm) - choose your bore (36, 38, 40, and 42 mm). They are less than $300 each. And rotors are cheap! BTW, who builds a 'race car' without a bias adjuster?
EDIT: the rears are 500 each...
Old 11-18-2014, 01:26 PM   #27
CSG Mike
CSG Mike's Avatar
Funny, I'm having lunch with the friction engineer tomorrow...
Old 11-18-2014, 01:53 PM   #28
Cool, wasn't sure how serious your build will be.
Seems like you've got a good background already with brakes and specifically brembo. Please keep us posted on what you end up with!
- Andy
Brembo Big Brake Kits and Fluid! GT/GT-R/Club Race Corner3garage Brakes, Suspension, Chassis 106 04-24-2015 02:36 PM
STI Brembo HELP ~ Trap63 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 08-02-2013 07:59 PM
86 to Race inaugural Moder Sports Car Race 000 Racing AUSTRALIA 4 05-23-2013 07:22 PM
No Race Track Seats in Race Car Drivers Every Day Cars..!! JohnnyNight Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 05:42 PM
Toyota FT-86 to Race in VLN Race @ Nurburgring this Weekend! First Photos! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 329 10-16-2011 09:51 PM
