Old 11-10-2014, 12:46 PM   #197
xwd
Well that's what you want to see, I'm assuming that's based on the initial pulley that comes with the kit?
It's also nice to see a vendor gather that kind of information, I haven't seen it from anyone else... I have a dual temp gauge I was going to use but I don't have a way to datalog it really, just show a difference between inlet and outlet on a display.
Old 11-10-2014, 01:10 PM   #198
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by Kodename47 View Post
This has surfaced from a UK vendor on the kit:
Interesting, it would be nice to see a graph with multiple pulls in a row as the temp does start to spike once it gets to 5.5-6Krpm.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 11-10-2014, 01:11 PM   #199
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
If the cosworth kit gets a CARB EO #, then I'm in.
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
OICU812 (11-10-2014)
Old 11-10-2014, 01:26 PM   #200
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
The exchanger itself, IIRC, was a 2 pass unit (might be a 4) that was approximately 55-60% of the width of the radiator. The impact beam on the car was replaced with a beat rush bar to give the entire heat exchanger airflow. With a stock impact beam, a substantial portion would be covered.
Am I understanding that correctly - with the Cosworth 2.0, you'd have to use an aftermarket impact beam to get the maximum efficiency of the intercooler?
Jyn is offline   Reply With Quote
Old 11-10-2014, 01:28 PM   #201
Shady195
Drives: '13 10 Series FRS #1203
Was curious about this as well. Thats what it sounded like
Shady195 is offline   Reply With Quote
Old 11-10-2014, 03:28 PM   #202
CSG Mike
CSG Mike's Avatar
Based on what I've seen, yes.
The height of the heat exchanger is similar to that of the FMIC in the Greddy turbo kit, although the hoses go around to the side, not through the top.
Old 11-10-2014, 07:02 PM   #203
Jyn
Noob
Jyn's Avatar
That's disappointing, but I suppose there really wasn't any other way Thanks, though!
Old 11-11-2014, 01:58 AM   #204
GTO2BRZ
Drives: 2015 BRZ
Both are pursuing CARB. Whether they will follow through or not is a different story, but based on the reputation of the companies, I'd give Cosworth a pretty good chance, and the other company will not release a non-CARB product.
Cosworth should be submitting the initial CARB application in the near future, after a CARB tune is developed.
Awesome! The Jackson is at the top of my list right now but it's always good to have more options.
CSG is not too far from me, I'll definitely touch base with you guys before buying. Thanks for all that you guys do for our community.
GTO2BRZ is offline   Reply With Quote
Old 11-11-2014, 08:07 AM   #205
350matt
Drives: toyota mr2/ Toyota GT86
nothing to stop you running it with the standard cross beam though?
350matt is offline   Reply With Quote
Old 11-11-2014, 10:05 AM   #206
Jyn
Noob
Jyn's Avatar
You won't have full utilization of the intercooler. I wouldn't feel comfortable running Cosworth's tune that's optimized for a fully exposed IC. More importantly, if you were tuning outside of Cosworth's specs (say, to up to power output), you may not be able to go as high.
It'd basically be paying for something that doesn't get utilized. Waste of money, imo.
Old 11-11-2014, 02:31 PM   #207
350matt
I wouldn't worry about that, I've seen the Cosworth development car its running a standard crash beam - looks to me like they used all the available space to maximise thermal inertia as well as cooling - after all the stock rad is partially blanked by the crash beam too
so if you do run a aftermarket beam then you'll get better cooling as bonus
The Following 2 Users Say Thank You to 350matt For This Useful Post:
CSG Mike (11-11-2014), zdr93523 (11-18-2014)
Old 11-11-2014, 02:34 PM   #208
Jyn
Noob
Jyn's Avatar
Interesting. I wonder why they decided to swap to the aftermarket crash beam then.
After my last F/I car, the only thing holding me back from boosting the FR-S is longevity. There's a reason you see so many people listing their cars FS a few months after they've boosted it.
Old 11-11-2014, 02:50 PM   #209
350matt
I suspect the rallysport car on the cosworth stand is a show car with lots of nice bits on it, after all its not cosworth's car , it just has the cosworth kit on it as they are a cosworth vendor
and yes you make an interesting point about long term longevity, I suspect most folks whack on a FI kit and go for broke without thinking just how long the stock bottom end will last
I'd hope that Cosworth have considered this with this kit, hence why the boost is pegged much lower than what the charger is capable of to help keep the stock bottom end alive
Old 11-11-2014, 02:58 PM   #210
Koa
A lot is working against this car's ability to be FI; the whole drivetrain should be considered, not just the motor.
The high compression FA20 doesn't warrant great results boosted without getting into the guts with some lower compression, forged internals, and whatnot
Cosworth FA20 Stage 1 Power Package DaDr00 Engine, Exhaust, Transmission 84 06-10-2016 04:02 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 11:10 AM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 11:16 PM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 02:23 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 08:29 PM
