Old 11-06-2014, 11:54 AM   #1
FRiSson
Drives: FR-S MT
rythmic noise/grind from the back end
I hear and feel a mild "chuffing" noise and slight grind that changes with speed of the car.
I have ruled out brakes, since it occurs with or without the brakes on.
I hear it on smooth pavement, otherwise there is too much road and car noise to hear it well. I have not been able to duplicate it with a mechanic in the car.
I have ruled out transmission, since it occurs when the car in neutral and/or the clutch disengaged.
It might be tires, but the low-speed noise and sense of grinding kind of argues against that.
Could it be differential, LSD, bearings???
FRiSson is offline   Reply With Quote
Old 11-06-2014, 01:00 PM   #2
White64Goat
Believe that some owners have had noise from the Limited Slip Diff. and did a fluid change, after that, not sure. I'd try a fluid change first and see if it helps any.
Old 11-06-2014, 01:10 PM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
This car does not have an LSD.
Are you on stock suspension? Is it the driveshaft carrier bearing? When I first lowered it the toe was out enough to make some road noise on my way to get an alignment.
Old 11-06-2014, 03:12 PM   #4
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Exsqueeze me, wot?!?!?
[ame="http://www.youtube.com/watch?v=u0EOrzn7-Qc&sns=sms"]2013 Scion FR-S | Torsen® Limited Slip Differential Explained - YouTube[/ame]
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 11-06-2014, 03:29 PM   #5
White64Goat
Uh.......yeah it does..............
Old 11-06-2014, 05:30 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
[ame="http://en.wikipedia.org/wiki/Torsen"]Torsen - Wikipedia, the free encyclopedia[/ame]
Old 11-06-2014, 05:51 PM   #7
kodyo
Drives: Scion FR-S
From my experience rebuilding my own diff, I'll try to chip in to the best I can. As far as I could tell on my diff, the diff gearing itself really only made noise under load (so accelerating or engine braking). So I doubt it's the ring/pinion gears. If it was the actual diff, I would think the noise would be more prominent around corners, is this the case? If it were a bearing, it would be more of a whirring noise, is that what you mean by "chuffing"?
If you are up for trying things, I'd replace the diff fluid and see if it changes the noise at all. Inspect the plug as well for shavings. A decent amount of shavings/sludge on the plug is fairly normal if you haven't changed the fluid yet.
Is it more prominent from any particular side? This may indicate axle or wheel bearing issue on that side.
Any mods to the car? Any adjustments to the clutch?
kodyo is offline   Reply With Quote
Old 11-06-2014, 10:40 PM   #8
Cal3000
Drives: Panda FR-S
I have a strange tin can like rattling noise also. It has progressively got louder and is borderline annoying now. The noise started when I changed my tires. Someone else on this forum heard rattling from their aluminum valve stem being loose that sets in the wheel. Ill go to the tire shop and have them check it out.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 11-06-2014, 10:50 PM   #9
Reaper
Reaper's Avatar
Drives: violent
Originally Posted by White64Goat View Post
Attachment 95191
Nope. No lsd. Torsen.
Old 11-06-2014, 10:55 PM   #10
Fastbrew
Drives: 2014 Pearl White BRZ
Torsen (full name Torsen traction) is a type of limited-slip differential used in automobiles.
[ame="https://www.youtube.com/watch?v=u0EOrzn7-Qc#t=48"]2013 Scion FR-S | Torsen® Limited Slip Differential Explained - YouTube[/ame]
Fastbrew is offline   Reply With Quote
Old 11-06-2014, 11:03 PM   #11
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Right. I forgot nobody can be wrong on the internet without being correctly in the most childish way possible. Big red print. Gold star bucko.
To the OP: do you have any sort of suspension mods? The way you describe it, it almost sounds like you're grounding out the car.
On a different note, when the noise occurs, does the car react in any way (slowing down, etc) or does the noise cause the car to vibrate?
Bobblehead is offline   Reply With Quote
Old 11-07-2014, 02:18 AM   #12
Fastbrew
He had already been corrected once - I thought a little visual aid might help. It has worked for me and it appears to have worked here. Perhaps I should have just used BOLD - Big Red is kinda like passing double-dog-dare and going right for the triple dog dare - so I acknowledge a slight breach in etiquette but you can't deny the effectiveness.
The Following User Says Thank You to Fastbrew For This Useful Post:
kodyo (11-07-2014)
Old 11-07-2014, 03:57 PM   #13
FRiSson
Drives: FR-S MT
The car is stock the sound is like a rapid chuff chuff chuff sound at 20mph same on straights as on curves
Old 11-07-2014, 07:05 PM   #14
kodyo
Drives: Scion FR-S
Check your tire tread and see if anything is stuck to the tread, or if the tread is worn down too much. Check that nothing is rubbing on the wheels such as a body panel or piece of road debris. Make sure you have all of the plastic rivets that hold the liners in place. I've had the plastic under panels make a scraping/chuffing noise at speed once some wind can get behind it and make it flop around while missing some of the plastic rivets.
4th gear grind aaguirre123 Engine, Exhaust, Transmission 8 08-03-2015 04:58 PM
2nd gear grind (yup another one) SmartedPanda Issues | Warranty | Recalls / TSB 17 09-10-2014 04:02 PM
4th gear grind Moetivegt86 Issues | Warranty | Recalls / TSB 10 03-07-2014 11:50 AM
Very annoying rattle/noise in the back of my BRZ. Any help? MrGamer BRZ First-Gen (2012+) — General Topics 6 08-02-2013 09:32 AM
weird plastic squeaking noise (back seats) whyreeto AUSTRALIA 5 09-17-2012 01:34 AM
