#2073 |
in orbe terrum non visi
Drives: violent
Can someone throw me a link to some sway bar comparisons? Can't seem to find a breakdown of the market.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#2074 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#2075 | |
http://www.harborfreight.com/14-in-3...het-67994.html |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Campo (11-13-2014), ZionsWrath (11-01-2014) |
#2076 |
Drives: Scion FR-S Whiteout
Mike, which brand of torque wrench would you recommend?
2013 Scion FR-S
#2077 |
Because compromise ®
Drives: Red Herring
[pedant]
I apologise for this but I have this insatiable urge to amend this reply. on LHD cars. [/pedant]
| The Following User Says Thank You to Captain Snooze For This Useful Post: | CSG Mike (11-02-2014) |
#2078 |
Drives: violent
I am definitely thinking stiff bars soft springs for my turbo mostly street car. I need a little front back weight transfer for traction. Eibach sways on full stiff might be in order. Maybe 7k springs? Maybe a little softer? Anyone running something similar on the track?
#2079 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Using left and right doesn't work if you're facing backwards but port and starboard is based on facing forward so avoids that confusion. Or, just a convention that left and right are based on when facing forward.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#2080 |
Off Topic
A good example of using the entire track.
#2081 |
This seven-second clip shows what that looks like from inside a car:
[ame="https://www.youtube.com/watch?v=b1o-3CEyS44"]T11 Exit Wall at Watkins Glen - AP - YouTube[/ame] So far, I've had no success in getting students to do this. Obviously, it's not for novices, but as long as you keep your eyes up and down the track (where they're already supposed to be), you can can get up against that wall in perfect safety - the curbing doesn't upset the car, the cushion of air that a car will create and compress against a wall is present and can be felt, your peripheral vision will keep you informed as to where you are, and...it's fun! Last edited by dradernh; 11-02-2014 at 07:34 PM. |
#2082 |
Drives: 2013 Whiteout FR-S
What can I do to get better traction out of the rear coming out of a corner? I put on the whiteline positive traction inserts.. it definitely feels a LOT better.. but I feel like it's about to slip still.. any recommendations? Maybe a sway bar? I still have the stock sway bar on for now..
TEAM NEMESIS | NEM 86 | IG: @NEM_86 PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics The NEM86 Build Thread |
#2083 | |
driving smoother faster
Drives: Sold
Camber, tires, clutch LSD, shocks...stock sways work well for me |
#2084 |
i have -2.5 degrees camber in the rear with 255/35 RS3 tires.. I do need to upgrade the LSD.. i have kwv3s
#2085 |
#2086 | |
Drives: '23 BRZ Limited
Have you been using a probe to check your tire temp (edit sorry)? What's your temp spread? What's your alignment? What psi are you running? It's possible to run too much camber/not enough toe-in. Last edited by OkieSnuffBox; 11-04-2014 at 09:46 PM. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
