Old 10-16-2014, 02:42 PM   #1
Model Citizen
Lacking brains
Drives: frz
Car idles great, dies on throttle.
Cross posting this from the fi section to get some more direction to go in.
Car has kw sc, vta catch can, stock on engine otherwise.
So far i've checked all sc kit plumbing, all vaccum lines (including spraying with cleaner), put a boroscope on the throttle body and sc turbine, changed the plugs, picked up a spare coil pack, removed the sc from the picture (reroute plumbing directly, stock map sensor, stock tune), put the sc back into the loop as it was.
Vehicle cuts power and evetually dies under throttle application, currently around 2.5k rpm. Especially now with new plugs the idle is smooth, video was pre plug change. No cel.
http://www.datazap.me/u/utekineir/ne...0&data=5-41-66
[ame="https://www.youtube.com/watch?v=m-P_7FVZ71g&list=UUhvDJ0loszAdzRWUwe6V3-A"]External - YouTube[/ame]
passenger side
image by utekineir, on Flickr
Driver side
Right now i'm leaning toward a fueling issue. Unfortunately i'm log retarded when it comes to reading them.
Thanks,
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 10-16-2014, 04:26 PM   #2
Moskoi
Drives: Subaru BRZ 6MT WRB
Did the car started to do that all of a sudden? Any check engine codes?
Maybe fuel pressure. To test if it's fuel pressure related, apply throttle and spray in some carb cleaner in the intake. It may backfire from the throttle body, so take care. If you can run the engine with the carb cleaner, the fuel pressure is too low.
I would guess that the timing chain is off, the ecu would trigger the spark way off the normal timing when throttle is applied.
Moskoi is offline   Reply With Quote
The Following User Says Thank You to Moskoi For This Useful Post:
Model Citizen (10-16-2014)
Old 10-16-2014, 06:00 PM   #3
Model Citizen
Lacking brains
Drives: frz
No cel, happened in the middle of driving and required me picking up my trailer to tow the vehicle home.
New video, same symptoms.
[ame="https://www.youtube.com/watch?v=m-j7mBo26JM"]Power cut - YouTube[/ame]
Old 10-16-2014, 06:44 PM   #4
Model Citizen
Lacking brains
Drives: frz
tried it at idle, instant kill.
Old 10-19-2014, 11:38 AM   #5
Model Citizen
Lacking brains
Drives: frz
This looks like a valid culprit.
Old 10-20-2014, 12:40 PM   #6
Moskoi
What is it?
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 01:20 PM
Car dies after 15-20 minutes? PolishFrs13 Issues | Warranty | Recalls / TSB 28 10-08-2015 05:28 PM
Used car from dealership randomly dies, what to do? mike the snake Off-Topic Lounge [WARNING: NO POLITICS] 11 08-20-2014 08:41 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 01:44 PM
