Old 09-15-2014, 07:49 AM   #155
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Ah, yes, of course (that's the problem with that strategy!).
What you could do then is just copy the above code into the xml that you are using for romraider.
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
steve99 (09-15-2014)
Old 09-24-2014, 08:25 PM   #156
tech86
Drives: 86 GTS
Originally Posted by Td-d View Post
Tables are there ...
Code:
<table name="MAF Correction After Start (Neutral)" storageaddress="11C868">
  <table type="X Axis" storageaddress="11C81C" />
  <table type="Y Axis" storageaddress="11C848" />
</table>
<table name="MAF Correction After Start (In Gear)" storageaddress="11C964">
    <table type="X Axis" storageaddress="11C918" />
    <table type="Y Axis" storageaddress="11C944" />
</table>
Is it just me or are those tables (obviously diff address) defined in the RR version of the A01G def but not the ecuflash one?
tech86 is offline   Reply With Quote
Old 09-25-2014, 07:08 AM   #157
Td-d
I'm not sure if I added those to the 32bitbase for Ecuflash, can't recall - I'll check.
tech86 (09-25-2014)
Old 09-25-2014, 10:21 PM   #158
tech86
Drives: 86 GTS
There are no "MAF Correction" records in 32bitbase that I can find.
Old 09-26-2014, 02:53 AM   #159
steve99
Drives: FT86
If your on A01G rom those maf correction after startup tables are available in romraider defs on github .
Old 09-29-2014, 02:17 AM   #160
tech86
Drives: 86 GTS
Yeah I know, but they're not in the ecuflash def's for the same ROM ID?
vs
Old 09-29-2014, 04:40 AM   #161
steve99
Drives: FT86
vs
they are in the A01G romraider defs
Old 09-30-2014, 05:09 PM   #162
ZoM
Drives: 2014 Monogram Raven 86
@Shiv@Openflash is it possible to add these tables to the v2.0 ots xmls?
ZoM is offline   Reply With Quote
Old 09-30-2014, 05:48 PM   #163
steve99
Drives: FT86
If you just want to quiet down cold start you only rearly need to reduce the amount of ignition retard applied and maybe drop the rpm down, the maf tables are not rearly needed its just a nice to do part. did a trhead on tune tweeks its linked in the OFT TIPS thread below
its mainly the amount of ignition retard applied that increases the noise levels. reduce that from -15 to -4 or even 0 and the noise is gone.
Old 09-30-2014, 09:08 PM   #164
tech86
Drives: 86 GTS
Yeah we established that but since I edit/write from ecuflash, I like to be able to see all the tables there rather than have to open RR.
The amount of work for maintaining the def's has grown exponentially so I can see why it is no easy feat to keep them all aligned.
Old 09-30-2014, 11:08 PM   #165
steve99
Drives: FT86
I work the other way arround do all editing in RR then just flash with OFT or ecuflash so as long as the ecuflash basic def is ok it all good as i only use it to flash.
Old 10-07-2014, 12:04 PM   #166
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
So I've tried this route, only changing the the ignition retard to -4.18 and it no longer idles rough, however it's still stupid loud and on a chilly-but-not-so-cold day it initially idles at ~2100 rpm before dropping down. Not rough but still loud.
I've checked my Idle Speed Target A and B tables and they have a max value of only 1400, so I'm not sure why it idles so high. Have you got any advice for me that might prevent my neighbors from burning my house down?
AdrianG is offline   Reply With Quote
Old 10-07-2014, 06:25 PM   #167
steve99
Drives: FT86
Check all the idle target tables and see none have high values over 1400
you can probably reduce the retard from -4 to Zero as well.
Old 10-07-2014, 07:13 PM   #168
troek
troek's Avatar
Drives: 2012 Toyota 86
for the the biggest difference was the maf correcction after start tables. if you dont have those in romraider, shoot me a pm with your email address, and what cal rom you use.
troek is offline   Reply With Quote
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 03:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-13-2015 12:53 AM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 07:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 02:35 PM
