#799 | |
PhoneFlash by EcuTeK
Hi Calum, I sent you an email on August 15th 2014. Please check your spam, as it has the latest version 5.33 and the evap codes are all active. I am resending, but please check your spam and make sure my emails are not going into them. Cheers, William Knose Delicious Tuning |
#800 | |
That Guy
Drives: 2013 asphalt FRS MT
#801 | |
OK, everyone starting immediately unless specifically told in your order, all check engine lights stay ON. I tried to be helpful and all it has done if cause more problems on our end. I will make a note on the website as such. As for your tune, your current tune as I reviewed it has the EVAP codes active which was sent to you in August. Cheers, William Knose |
#802 | |
But we would need to charge a service to adjust it. Or if you want to come by the shop we can see about dialing it in person. Cheers, William Knose Delicious Tuning |
#803 | |
I just checked your tune and it has everything active with respect to the EVAP codes as it should be from the factory. It looks as though we did shut off a couple other codes though that relate to Mass Air Flow Limits but that is about it. I am not sure how that would affect it. Are you sure you are on the latest tune with the EVAP codes active? I will resend the email I sent on Sept 8th. Cheers, William Knose Delicious Tuning |
#804 | |
Professional Smartass
Drives: White Out FRS
I can't connect the wideband to the rear o2 input because I have flex fuel connected to that input. Same car, same setup, your newest tune you resent vs other tune from someone else. As soon as I fire up the car it throws evap codes high low voltage. Which makes sense because there is no evap voltage, its the ethanol sensor voltage and the car is like wtf. I will try the tune you just sent me and report back. Maybe the logic for the evap needs to be adjusted so any voltage is in the normal range? Maybe that's how the other tuner does it? |
#805 | |
OK, understand now. Sorry I usually just shut off all the evap codes (14 in total) for FlexFuel as we have seen that down the road (1000 miles or more) you can possibly get other evap codes, such as P0451 or any of the other 11 evap codes. In total there are 14 different codes, as we shut them all off because of the situations we have seen above. Rare but they happen. Cheers, William Knose Delicious Tuning |
#806 | |
#807 | |
Things are bit stressful with the new baby arriving tomorrow. And basically I will be our of commission for the week. So I am trying to get whatever I can wrapped up before then. When we return, we will have a lot of new stuff. 1. FlexFuel Kit Release (Coming SEMA 2014) 2. Android Head Units (for custom spec Delicious Android gauges) 3. Flash and Go Updates 4. Supercharged Stroller Cheers, William Knose Delicious Tuning |
| The Following 6 Users Say Thank You to DeliciousTuning For This Useful Post: | Calum (09-28-2014), fasteddy (10-23-2014), JDLAutoDesign (09-30-2014), Lawnik (09-28-2014), MINOCIN (09-30-2014), post_break (09-28-2014) |
#808 |
That Guy
What's the chances of things like time alignment and active crossovers in that android head unit? Something like that might get me to finally finish my stereo install.
#809 | |
USMC
Drives: 2013 FR-S 6-MT Raven
#810 | |
I mean if we can't get this fixed, I guess I can take my glove box out, unplug my harness, go pass inspection, and then plug it back in. It's just those connectors are a bitch to get to. We'll figure something out, I don't need to pass inspection soon so I'm not in a rush.
#811 |
USMC
Sorry Bill I really thought I'd be able to make it out today. Plans changed at the range and didn't get off until 5pm. When do you guys close?
#812 |
Hope the baby and mom are doing good!
I decided to say screw it, I took the harness out and now evap is hooked up as if stock. The latest tune you gave me does not go to ready, but I think the tune before that will work just fine. I will test it and report the all clear. It just kind of sucks because I paid for the work so I could log my wideband in ecutek. But if I have to rip that thing out every time I need to pass inspection it just isn't worth it. |
| Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 24 | 09-20-2013 03:04 PM |
| Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-19-2013 05:58 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 01:34 AM |
| Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK | DeliciousTuning | Announcements, Contests, Giveaways | 5 | 08-26-2013 02:33 PM |
