Koji_Online
Old 08-12-2014, 03:39 PM   #519
JDis3
JDis3's Avatar
Drives: is300 / Fr-s
Originally Posted by codesplice View Post
Doh! You did, my bad.
But yes, it is correct. There should just be a tiny bit of the white plastic switch sticking up beyond the metal threads. You don't want the pedal arm to actually touch those threads, just the plastic bit. In general, if you can still lift the clutch with your hand slightly above where it rests you're probably good.
thank you someone who actually responded to if it it was correct or not, now ill have to spin the clevis a few times to get the clutch off the threading
Daily Driver:2002 Lexus is300 Graphite Gray Pearl
Garage Queen:2014 Monogram Fr-s Asphalt 6MT
my.is: iJAYDM Clublexus: JDis3 IG:@j0nathandiaz
JDis3 is offline   Reply With Quote
The Following User Says Thank You to JDis3 For This Useful Post:
codesplice (08-12-2014)
Old 08-12-2014, 04:09 PM   #520
JB86'd
JB86'd's Avatar
Drives: JAWS
If your pedal is at a good height you can just adjust the sensor up or down..
JB86'd is offline   Reply With Quote
Old 08-12-2014, 04:32 PM   #521
JDis3
JDis3's Avatar
I adjusted the pedal so many times yesterday that its actually much higher than the brake pedal, most likely back to stock height. Once I readjust it later today ill check back in here to update on my progress
Old 08-12-2014, 05:34 PM   #522
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
This may be too far OT, but does anyone know if we can adjust the gas pedal so all 3 pedals are equal height? I know when flashing a new tune, the car needs to relearn the range of gas pedal motion, so I'm thinking this may be as simple as the clutch is to adjust. Anyone tried this?
xxBrun0xx is offline   Reply With Quote
Old 09-08-2014, 12:33 AM   #523
n0thing
Drives: Subaru BRZ
Remove the two 10mm nuts securing the gas pedal assembly and insert spacers as needed.
n0thing is offline   Reply With Quote
Old 09-17-2014, 01:35 AM   #524
504
504's Avatar
Drives: 2014 86 GTS
So I'm having an issue recently developed where the car thinks I have the clutch fully engaged any time my key fob comes near the car and allows me to turn the engine on without pressing the clutch. I cant get into accessory or ON position without starting the car any more. The key fob light is lit solid green on the dash when I'm in it and the push to start is always red. I have done the clutch spring removal as well as the clutch adjustment to level the clutch pedal with the brake maybe slightly higher and made sure to adjust the sensor in the correct manner
Just my thoughts on the issue; I don't think the spring is at fault cause it puts force on the pedal at full engage or full disengage regions only. I pushed the pedal back with my hands as far as possible and it still senses the clutch is engaged so I don't think its related. This also started happening yesterday and I had the spring removed a few days earlier without issue. I've done clutch adjustments nearly daily but made sure to have the sensor positioned perfectly so I also do not see it as being the issue
Any help would be greatly appreciated
Edit: found the solution to this if anyone else is experiencing the same problem; There's a black sensor which gets pushed in when clutch is fully depressed and for me it started to jam and hold on giving the signal the clutch was depressed. The sensor jams when pressed in too far so adjusting it further back with a 14 mm wrench will fix the problem!
504 is offline   Reply With Quote
Old 09-17-2014, 12:21 PM   #525
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Love the thread and discussion on adjusting the clutch. So far running Exedy's Hyper Single (secretly upgraded) it definitely has a heavier pedal than the Clutch Masters FX350. So far I have left everything stock and think it's a pretty good feel.
But I am still debating on what the feel will be like with removing the "helper spring." Anyone have an opinion that are running a heavier pressure plate (aka FX400 & up, Hyper Multi, Hyper Single, or a pressure plate with 2600lbs and up)? Thanks guys.
*Tags added to thread
shiro is offline   Reply With Quote
Old 10-27-2014, 03:24 PM   #526
SEAMUS
Drives: 2014 Subaru BRZ
After driving my '14 BRZ for 3 months, I still felt I hadn't mastered shifting. Occasionally killing the engine at launch, over-revving and just having to think about shifting too much surprised me after having shifted Porsche's, Vettes and Jaguars going back to the late sixties. After finding and reading all of this thread, I decided to adjust the clutch pedal height.
My pedal came from the factory a full 3/4" higher than the brake pedal. I used the method some suggested of backing off the nut, popping the pin and spinning the bracket down 1-1/2 turns, reinstalling the pin and clevis, re-tightening the nut and then taking it for a test spin. This ten minute fix sure seems to have made a big difference. Now the clutch pedal is still a good 1/8" higher than the brake. I'm erring on this relative height, being on the safe side from what I've read here but, so far, seems to be all that's needed. The only thing I didn't figure out was how to get the white nylon part back on the end of the pin. What's it's purpose, anyhow?
Thanks to those that did all the groundwork for this mod. It's much appreciated.
SEAMUS is offline   Reply With Quote
Old 11-18-2014, 09:57 PM   #527
iarefluffy
iarefluffy's Avatar
Drives: CWP series blue brz
so... is it SAFE to adjust the clutch pedal? :o
iarefluffy is offline   Reply With Quote
Old 11-21-2014, 02:09 PM   #528
Koa
Yes. Yes it is. Just don't make it unsafe
Old 11-24-2014, 07:22 PM   #529
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
Not sure why you would take off the clevis, its designed so you don't need to.
jonboy99 is offline   Reply With Quote
Old 11-25-2014, 07:52 PM   #530
86Heritage
Drives: 2015 Asphalt FR-S
Subscribed! This looks very useful!
86Heritage is offline   Reply With Quote
Old 11-28-2014, 01:33 PM   #531
xxBrun0xx
xxBrun0xx's Avatar
Just wanted to report back after 8 months of having the clutch a mm above the brake pedal and the helper spring removed. Forget turbos and coilovers, this and the spring removal is the absolute best thing you can do to your car.
The Following 2 Users Say Thank You to xxBrun0xx For This Useful Post:
JB86'd (11-28-2014), Stealthy (11-28-2014)
Old 11-28-2014, 04:05 PM   #532
-____-
JB86'd (11-28-2014), Koa (11-28-2014)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 11:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 03:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 02:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
