go_a_way1
Old 09-16-2014, 08:31 AM   #2507
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by jn86 View Post
Hey guys, I've searched this thread quite a bit and gotten a vague idea of an answer but just want to be sure:
Looking to go 18x9 et38 XD9s all round and I’m currently on a 1” drop from Eibach pro kit springs. Now due to the laws in Australia I can’t poke out any further than the stock fenders (correct me if my wording is a bit off).
With 235/40/18 or 245/35/18, would this be fine to avoid rubbing as well as poking in order to stay legal?
Perfect flushness isn’t that much of a concern, just want to avoid being defected!
Daily driving use btw.
Much appreciated.
Good choice of wheel size and offset. I would go with a 245/35 size as it matches OEM size for diameter and it will still have a wee bit of stretch. My Sig below shows that tire (Conti Extreme DW) in 245/35R18 on a 18x9 wheel.
Slick is offline   Reply With Quote
Old 09-16-2014, 10:29 AM   #2508
jn86
Drives: white gt86
I'm just concerned with the poke mostly, props to your set up btw
I'm also thinking of running 17x7.5 fronts and 17x8.5 rears et42 for both (xd9s) as a mate has a set he's willing to sell to me. I would much rather be safe than sorry with the law over here.
I have a set of 215/45/17 lying around, would they be alright to use for both front and rear?
Sorry for all the noob questions
jn86 is offline   Reply With Quote
Old 09-16-2014, 10:43 AM   #2509
Slick
Slick's Avatar
Those would be good also, much less aggressive of course, so yeah you would be pretty safe. The tires would be okay on the fronts, but would be stretched for the rears. Not optimal, but would do until you get another proper set. I've seen crazy stretches like 205's on 9's and 10's.
Ideal size tire for those wheels would be 225/45R17 and 245/40R17.
Old 09-16-2014, 11:44 AM   #2510
twag4
Drives: frs
18"x9", +45 square with 245-35 18 on stock suspension (eventually lowered 1")?
twag4 is offline   Reply With Quote
Old 09-16-2014, 11:55 AM   #2511
Slick
Slick's Avatar
What suspension currently and planned for future?
You will need a +35 offset or 10mm spacers if you want to run these either stock or dropped on springs, but will fit with coilovers.
I would still try getting something closer to a +35 to +38 offset.
The Following User Says Thank You to Slick For This Useful Post:
twag4 (09-16-2014)
Old 09-17-2014, 01:34 PM   #2512
twag4
Drives: frs
Will I only have trouble on rear, or front too? As far as suspension, maybe coil overs, not looking for a large drop as I hit now with the large drainage they build into streets here in the Deep South if I'm not careful.
Old 09-17-2014, 01:50 PM   #2513
Slick
Slick's Avatar
You should be clear on the rears but I would still run a spacer if you are running the same wheels up front, otherwise it will look strange running flush up front and tucked in on the rears.
If you run coil-overs, then you'll be okay upfront with a +45 offset.
So, options:
Running springs - use 10mm spacer on fronts and rears
Coilovers - no spacers required
Other option is to run staggered with a different size wheel up front:
18x7.5-8" up front (offset range +40 to +45) and the 18x9 +45 wheels in the back.
twag4 (09-19-2014)
Old 09-18-2014, 09:58 PM   #2514
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
Will this fit? (width, offset and tire size Qs)
18x8.5 +48 rota g force wrapped in 225/40zr18 okay? Stock suspension. Eventually either sport line or pro kit drop.
RocketBunny FRS // Phantom ESC // OFT x E85
Dallen is offline   Reply With Quote
Old 09-21-2014, 08:13 PM   #2515
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
I'm looking to get Enkei Kojin 18 x 8.5 et45 front and 18 x 9.5 et45 rear
I'll be running stock suspension for the time being to stay in my autocross class (i'll be switching to stock wheels for c street)
for tires I was thinking 235/45 for the front and 255/40 for the rear
The reason I want these sizes is to get as much sidewall as possible to fill the wheel gap
So i have two questions (hopefully someone can answer):
1. Will these wheels fit with out hitting the stock springs?
2. The overall diameter of the two tires will be off by 7mm (1/4''). Will this effect abs/tc?
thanks
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 09-21-2014, 08:55 PM   #2516
markkisl
markkisl's Avatar
Drives: Subaru BRZ - GBS
Looking at used xxr 527's. I'm not fimiliar with sizes and fitment so maybe you guys can help me out. Square set of 18x9.75 +20 running 245/40ZR18 tires. Will they fit with stock height? What about a 1in drop?
markkisl is offline   Reply With Quote
Old 09-24-2014, 12:34 AM   #2517
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
18x8.5 +44 Volk RE30's, lowered on RCE Yellows, stock strut bolts, HVT camber plates (running -2 camber up front).
Right now I have 225/40R18 Michelin PSS's...look pretty stretched and wondering if I could/should fit something wider all around. 245/35 looks real close to stock diameter...but will it fit without issues up front?
There really doesn't seem to be much room between the 225/40's and the spring perch of the stock struts...I can fit a fingertip by my fingernail in there, but that's pretty much it. Thoughts?
Phaedrus29 is offline   Reply With Quote
Old 09-25-2014, 03:51 PM   #2518
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
I've searched a bit and I've came to the conclusion that this will fit via posts and the wheel app but I would love a reassurance on the specs below:
Front: 17 x 7.5 +48 w/ 215/45/17 (Lowered 1 inch)
Rear: 17 x 9.0 +35
w/245/40/17 (Lowered 1.3 inch)
Also, would a 1.5 difference staggered setup cause any trouble?
Rabbit of Caerbonnog is offline   Reply With Quote
Old 09-28-2014, 12:42 PM   #2519
Slick
Slick's Avatar
That's a pretty high offset.
It will fit only on stock suspension and camber, but with very limited clearance.
As soon as you drop it, you'll need to be on coilovers or use spacers (~10mm) to gain clearance.
Old 09-28-2014, 01:36 PM   #2520
Slick
Slick's Avatar
thanks
Pretty much same answer as above, limited clearance but okay with stock suspension only.
Tire sizes listed are too tall.
Options:
Fronts: 225/40, 235/40 or 245/35R18.
Rear should be 245/35, 255/35R18. Think 265s are gonna be too tight.
You shouldn't have any ABS issues as long as tire sizes are similar overall diameter.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
