Old 09-12-2014, 08:23 AM   #239
Shady195
Drives: '13 10 Series FRS #1203
Figured I would just let everyone KNow i got my Open Port and successfully flashed my car without much issue..
However a couple of things..
1. I would update the original post, as the latest version of ECUFlash comes with the definition files needed, no need to do anything other than download ECU Flash
2. I had an issue from the start where my OpenPort would not finish reading my rom, it would get about 20% and fail.. I tried a million things then simply just swapped USB ports and it worked just fine. I even put it back in the original USB port I had it installed in and it happened again. I know that USB port is fine however I know some devices can be picky about how good its connection is and an "acceptable" error rate.
So if you have similar issues just try swapping the USB port you're in.
Shady195 is offline   Reply With Quote
Old 09-12-2014, 08:51 AM   #240
steve99
Drives: FT86
Its ok if your in USA but other guys need to download latest Defs for their region. The 32bitbase supplied is out of date as well. It will work but missing some parameters and does not have latest bug fix's.
The USB issue may be power, some ports on laptops may not supply current required for tactrix. The ODB ports connector can be a bit suspect on brz/86 as well.
Old 09-12-2014, 09:00 AM   #241
Shady195
Ahh okay that makes sense then.
Old 09-12-2014, 10:20 AM   #242
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Just to confirm...
1. Everyone needs the latest 32bitbase, regardless of location.
2. The defs that come with latest EcuFlash are ok out of the box for USA.
One more tune related question. I have a catless UEL header, ABE, and a K&N drop in and I want to run the stage 2 93 rom. A station I fill up at sometimes has 92, would I have a problem with this if running the 93 ROM, or should I use the 91 ROM if I want to use 92 gas. I can get 93 at an alternate gas station, though its not as convenient. What type of power differences are there between 91 and 93?
B-R-Z is offline   Reply With Quote
Old 09-12-2014, 03:52 PM   #243
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If you run a 93 rom with less than 93, you will probably lose some power. How much I'm not sure. The car will knock and then cut back on timing. You're better off running the 91 tune with the 92 gas.
The Following User Says Thank You to EAGLE5 For This Useful Post:
steve99 (09-12-2014)
Old 09-12-2014, 04:16 PM   #244
B-R-Z
B-R-Z's Avatar
As long as my car won't die then I'm fine. I can stick to 93, the 92 is just in a convenient spot between my house and work. Near home and work I have access to 93. Just wanted to get an idea just in case I had the 93 tune loaded and down the road found myself halfway home from work, running on fumes, and have no choice but 92. Or the guy working the pumps puts in 87 or something by accident, it's happened twice, one of them being today.
Old 09-12-2014, 04:36 PM   #245
Shady195
I hate going through NJ anytime I go down to long island.. I make sure I don't have to stop at a gas station can't stand someone else filling up my car.. IDK why just bothers me.
Old 09-12-2014, 05:12 PM   #246
B-R-Z
B-R-Z's Avatar
I know, I hate it too. Especially when I'm in a rush bc you have to wait for them to acknowledge you and start the pump, then recognize when the pump is done to take payment. And they sometimes go to put in 87 by habit even when you say 93.
Old 09-12-2014, 06:53 PM   #247
steve99
Drives: FT86
Just to confirm...
Agree with jismon7777 your better of running the 91 tune if your not putting in 93 gas allthe time. the difference between tune is only about 3 hp or so.
if the ecu is left to pull timing is quite agressive and pulls more than needed.
the ecu pulls timing after detecting knock so if you run 93 tune on less than 93 gass you will be in a cycle of knock ecu pulls timing , then ecu tries to return timing it knocks again then it pulls and cycle repeats.
basicly it best to run gass to suit tune, it ok to run better gass than tune requires but not lower quality
Old 09-17-2014, 01:21 PM   #248
XCO
Drives: GT86
has anyone already tried flashing the OFT v2.06 roms?
My stock rom is A00J, I plan to use the OFT v2.06 Stg2 UEL A01J rom.
will the A01J ecuflash defs from Td-d still work with the new OFT roms?
TIA
XCO is offline   Reply With Quote
Old 09-17-2014, 01:52 PM   #249
B-R-Z
B-R-Z's Avatar
I'm running OFT v2.06 stage 2 UEL A01G ROM flashed with the latest ecuflash using an openport 2.0. No issues at all with the flash.
Old 09-17-2014, 02:00 PM   #250
XCO
Drives: GT86
is it safe to flash a G rom if my stock is a J rom?
Old 09-17-2014, 02:25 PM   #251
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I would not suggest it, no - unless you're willing the check the ecu wiring diagram to make sure that they are identical.
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
Shady195 (09-17-2014)
Old 09-17-2014, 02:40 PM   #252
XCO
Drives: GT86
my stock rom is A00J, can i flash it with the OFT v2.06 A01J ROM and use the A01J ecuflash def from your github folder?
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
