#29 |
Drives: FRS
I would have done the suspension first and awsome set of tires before all the useless power that I had first. Spinning was fun but it got old real fast
| The Following User Says Thank You to lexusb3 For This Useful Post: | sw20kosh (08-12-2014) |
#30 |
Drives: 2013 MT Asphalt FRS
Really helpful thread guys
#31 |
Boosted Member
Drives: 2013 Subaru BRZ
-16.0 when cold, hovers between -18.5 and -19.2 when warm. If I beat on it and the oil temps are high it will get to -20.2 but then taper back down. When it was new I was seeing like -22 ballpark warmed up all the time. (this is all with A/C, defrost, etc turned off)
I am assuming the piston rings are starting to go, it burns a tiny bit of oil too. I'm sure If I stop ragging on her so hard she will last a while, but what fun is that? And besides.. the sooner she lets go, the sooner I will have an excuse to release funding from the wife for the rest of the engine build.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#32 |
NASA SpecE30 Racer
The only thing I would have changed was shifting the radiator forward and running a nice fan shroud with higher flowing fans instead of the fans mounted with zip ties to the radiator that comes with the Full Blown kit. Probably would have ended up with an @jamesm tune by now as well.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | dparnell (08-17-2014) |
#33 |
Interesting thread.
Personally feel like I would not change much because it was such a learning experience. I don't think the money and time invested was worth the pay off and hassle. But if the Vortech unit fails I will switch it out for JRSC with oil cooler. I would however physically ship the car out to be tuned on site, I don't like the up and back of remote tuning and trying to bug fix remotely takes way too much time for me. Then adding the trouble of proving it works and is reliable not just on a dyno but heat, cold, track, idling, different throttle situations etc.
#34 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#35 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
My BRZ doesn't actually get much track time. Having had quite a few modded cars I chose to keep it a street/autox vehicle to try and get the best HP/reliability ratio out of it. I have a swapped MX5 with now a rotrex kit for the track. When it comes down to it, it is perfectly balanced, eats cheaper tires, and has double the brakes of the BRZ with 300 less lbs in heft. For our innovate equipped BRZ to be a useful track toy, it would need: Oil cooler Big brakes Clutch Straight e85 (too much heat otherwise with the twin screw) Rear driveshafts Slicks Otherwise it would fall apart after just a few laps. Auto-x toy it is quite fun as is though. At the WBM we were running e30, and even still if you look at the video, it was more than a handful even with our trick RaceROM traction control. |
| The Following User Says Thank You to Xero-Limit For This Useful Post: | CSG Mike (08-26-2014) |
#36 |
Drives: 2016 Subaru WRX
I would have stayed with the Innovate kit I had and added the IC w/ @DeliciousTuning tune. While the JDL kit is great in the power aspect and beautiful quality, it was more power than I needed for what I use the car for. I have had some seriously high hp imports in the past. You can make this platform pretty quick but I'd rather have a nice balance. Now I am back to a pretty much stock powered 86 awaiting a new project.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
| The Following 2 Users Say Thank You to evo4g63 For This Useful Post: | DeliciousTuning (08-28-2014), J.C. (10-08-2014) |
#37 | |
#38 |
Drives: 22RE, FA20, 4G63
I'm in the second FRS, first NA mod (intake, header and tune) it was ok, but die young...
Currently with the vortech, at 9 psi it was good! (That last about 2-4 weeks) then the search of more power resume... Header, exhaust, custom intake, smaller pulley, fuel pump + injectors, tune and retune, final drive 4.8... That has been 15k miles and need/desire more! No issue with gas quality here, been using Sunoco 100 or mix 100 with 93, never less the 50:50. The thing is that I tough the supporting mods were an overkill for the setup I was making, WRONG BITCH!!!! Koyo rad + OEM fans; commute 195-200f, autocross or spirited drive 205-210f Mocal oil cooler (20 rows); commute 185-212, autocross or SD 230f AFR 14 at idle and 12 at WOT ...I'm a turbo guy, this is my first ever SC car, I miss the boost rush so much, if not for temps issues I would sell the vortech today and go turbo. But I plan to beat the car every day for the next couple of years so temp is really important to me. So what would I do different IF I start again? Mmmmmm I would like to try another car, but there isn't another platform "new" with the potential of the twins, at least that I could afford to rebuilt... As some comedian said "you can't fix stupid" so the next project couldn't have a stupid handling. |
| The Following User Says Thank You to AJPG For This Useful Post: | raven1231 (08-31-2014) |
#39 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
I am currently doing it all over, decided fuck the fa20 and my blower setup, dropped it all out for 2 extra cylinders and 2 turbos w/oem toyota reliability and 400+ whp
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
| The Following User Says Thank You to OmarGC For This Useful Post: | 6-Shift (09-15-2014) |
#40 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
Mine's not even FI yet and I already know I'm doing it wrong. When the motor goes ill either get a used Z06 or swap in a C7 LT1.
#41 |
Drives: 2015 scion frs
#42 |
Drives: 2014 BRZ
-Would have opted for recirculating WG
-Would have picked a kit that did not require cutting of crash beam -Would not have set the WG hose routing up incorrectly, causing a huge amount of time, money, and stress diagnosing. -Would not have had my charge pipe not clear the accessory belt after taking it or and off so many times diagnosing and chew a hole through it causing all sorts of problems -Would have took the money I wasted on the above mentioned, a wideband I never used, & the Crawford AOS that was a complete piece of shit with terrible design and put it towards a GTX2863. Instead I'm here with my PTE 4854 that has better than average but not great transient response...and not much headroom without running stupid hot. |
| Are FT86 owners future Ferrari / Lambo owners? | pantdino | Scion FR-S / Toyota 86 GT86 General Forum | 126 | 08-31-2014 08:23 PM |
| My car runs differently now vs. new. Does yours? | empower-auto | Issues | Warranty | Recalls / TSB | 2 | 07-08-2013 05:26 PM |
| JDM Taillights are wired differently from USDM | ZC6BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-29-2013 10:56 PM |
| Question, would 19'' wheels cause my car to brake differently? | Mr.Zoolittle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 06-29-2013 04:26 PM |
| FR-S\BRZ owners give thumbs up to AE86 owners | Oriental Life | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-13-2012 03:12 AM |
