#2017 |
Drives: 2013 Scion FRS
After polling, I believe that the injectors are the bottleneck and not the in-tank pump. I have one but I don't want to hassle with the install so I'll be selling it as soon as the dyno proves it's not needed.
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#2018 |
I wouldn't imagine you will as a local guy just changed injectors and ran 18lbs of boost on e85...turbo but still comparable demand on fuel.
| The Following User Says Thank You to captain_jack For This Useful Post: | nlowell (08-26-2014) |
#2019 |
Drives: The silvertrooper 10 series
The car is "tuned" by delicious tuning, the car seemed to run pretty good but after looking at the logs he sent a revision and it seems to be worse, We may need Bill to relook at it. This was one of the first few C38's he did so he may have come a long way since then.. a different BRZ that thats turbo'd put 277 to the wheel, completely embarrassed the supercharged BRZ.. we also have injectors, pump and smaller pulley to add to the C38 now and run e85
-Thomas |
#2020 |
Drives: A bunch of 'em...
Question: Does anyone make a nostril that can be cut into the bumper to get air into the filter?
My IATs down here in MX are ridiculous. |
#2021 |
What's the ambient temperature in Mexico and what's your IAT right now? It wouldn't make any difference if both are the same temps.
#2022 |
IATs got as hot as 165 F.
Ambient is closer to 110... |
#2023 |
#2024 |
Right after a 20 minute track session.
#2025 |
IAT should be the same as ambient temperature while you're moving. If you stop, you will heat soak and the IAT will rise. Considering the KW claims it's a cold air intake, this kind of moots their point. You can just cut the bumper and put a tiny scoop to funnel the air directly to the air filter and wrap the piping with gold DEI tape like what Cem did.
#2026 |
I know I can cut a hole, my question was, if there is a good looking solution out yet?
If there is, I'd make sure the dimensions I cut fit whatever nostril may be available ![]() Edit: I know the 350Z has one available... Might just try these... http://www.ebay.com/itm/FOR-NISSAN-3...f75f2a&vxp=mtr |
#2027 | |
#2028 |
Drives: 2013 BRZ Premium Dark Gray Metallic
I think I'm going with Seibon FA hood to deal with the engine bay heat issue. Side note Oil cooler kit ready for install. As you can see the hose are now pre-assembled and just wondering if I still need to clamp the lines. I think I'll visit my local Parker Store tomorrow.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
| The Following User Says Thank You to zoth For This Useful Post: | glamcem (08-28-2014) |
#2029 | |
Drives: 2022 BRZ Limited
#2030 |
I have a home grown oil cooler kit using the KW sandwich.
Not a big fan of their choice on placement and hoses... The sandwich is a billet work of art though! Need to check out Ken's car. BRB Edit: Don't seem to find a pic of Ken's FRS with a nostril... Got a link? |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
