Old 08-17-2014, 03:00 AM   #29
pantdino
Drives: Firestorm 2013 FR-S
Originally Posted by FRSBRZGT86FAN View Post
Seems pretty logical temps go up at high revs, then the fans kick on and then turn off because airflow through the vehicle has already increased
Highly unlikely. The sound you hear is just the engine on what is called "overrun"-- you have lifted off so the engine is being spun by the now decelerating car. This gives different sound
pantdino is offline   Reply With Quote
Old 08-17-2014, 10:12 PM   #30
Cal3000
Drives: Panda FR-S
Originally Posted by pantdino View Post
This is NOT true. Remember energy increases with the square of velocity.
Your engine might survive a trip above redline and it might not.
Yes, that's kinetic energy.
It would be pretty dumb if engineers designed a product and set an operation point near the failure point. Safety factor are an integral part of any mechanical or electrical design. That being said, there are a lot of people running this car to 8k rpm. Ive done it for a few thousand miles.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 08-19-2014, 01:52 AM   #31
charged86
charged86's Avatar
Originally Posted by djmm View Post
My wife mentioned to me a couple of times while I was driving that I treated my car badly due to the way I drove.
I drive like normal most of the time but I sometime floor it all of a sudden after driving normally for most of the trip. This is mostly to beat the traffic lights or to prevent some inconsiderate aggressive numnuts from cutting into my lane.
Mind you I don't rev past 7k but for example I drove at 40 mph say at 3krpm, I'd then floor it to past 6k within 2 seconds or so just to get extra speed quickly and then I would drive at "normal" rev again. Sometimes I could hear the engine residual whirl after that short burst and back at lower rev because I released the gas pedal to drop speed gradually.
Would this damage the engine in a long run? I've been reading many comments that the engine is designed to be revved high, if that's the case, what I do here won't really harm the engine as long as I am not doing it when the engine is cold?
I do feel guilty after doing those occasional short burst as I plan to baby and keep the car for a long time.
she should make you a sandwich
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-19-2014, 10:03 AM   #32
DarkSunrise
DarkSunrise's Avatar
30k miles and I've slammed into the rev limiter a few times when I had my mind on other things (merging onto the freeway, finding the braking point for turn one at thunderhill).
Haha I hate that feeling when you hit the rev limiter just before the braking point on a track. Just.. a little... further.. <fuel cut>... doh!
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Frishkorn (08-20-2014), strat61caster (08-19-2014)
Old 08-19-2014, 10:14 AM   #33
WNDSRFR
Drives: FR-S,GTI
You can't go above redline. It's got a rev limiter. You can hold the throttle to the floor all day and the engine can not go over the rev limit.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Old 08-19-2014, 10:28 AM   #34
Shady195
Drives: '13 10 Series FRS #1203
One would be surprised at how reliable any engine can be if properly maintained throughout its life...... Even the ones people say are garbage.
Shady195 is offline   Reply With Quote
Old 08-19-2014, 01:11 PM   #35
Ninja14
Drives: It's a car
Wtf, what is your wife doing out of the kitchen? There's sammiches to be made!
Ninja14 is offline   Reply With Quote
Old 08-19-2014, 04:25 PM   #36
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You can force the engine to exceed redline by downshifting and dumping the clutch, no rev limiter on a production automobile to my knowledge is going to stop that event, mechanical over-rev is a very real phenomenon.
Hopefully that's outside the scope of what the OP was wondering about.
Old 08-20-2014, 05:03 PM   #37
xRavenFRSx
xRavenFRSx's Avatar
Drives: 2014 Raven FR-S
Originally Posted by DarkSunrise View Post
Those of us who bring the car to the track are constantly at 5000-7400 RPM for 20-30 minutes at a time, and no issues there.
Just make sure to:
1) Warm the engine up first, and
2) Keep the RPMs under 7400 (redline)
and you shouldn't have any problems.
That's my typical morning drive to work. If I kill it, then its just time for a new engine!
xRavenFRSx is offline   Reply With Quote
What happens on a Boxer engine when there's too much Oil? @Art_Mighty Engine, Exhaust, Transmission 29 06-15-2014 05:36 PM
Boxer engine and temps SlinkyAvalanche Engine, Exhaust, Transmission 9 03-27-2014 04:00 PM
What makes the Boxer engine so special ZakD Scion FR-S / Toyota 86 GT86 General Forum 111 11-02-2012 10:54 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 01:04 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 11:55 PM
