#113 | |
#114 | |
Mmm, metal on metal. |
#115 | |
Drives: 2015 FRS
2015 FRS M6 Argento, 2014 Audi Q7, 2012 Audi A5 (Traded),2012 VW CC, 2010 Mercedes S550
#116 |
Drives: 2015 FRS
Mag Moss only prevents manufacturers from denying warranty claims for mods that were not material to the failure. However, failures that are linked materially to the mod are not protected. For example, if you install an aftermarket blower and you blow a rod, they can deny that claim. If you install an aftermarket brake kit and a strut fails, they can't deny that claim based on just the mod.
Presently, Audi and Mercedes are able to scan their ECU's and detect not only a performance upgrade program installed, but also if the ECU has ever been flashed at all. They're voiding powertrain warranties on those cars and inserting an electronic flag on the car that warns any tech who connects a scan tool that the car has no powertrain warranty and to stop work and return the car to the customer.
#117 | |
Drives: 2015 FRS
#118 |
Drives: 2015 FRS
Things take an ugly turn when folks start quoting Ron Burgundy.
| The Following User Says Thank You to FRS Dad For This Useful Post: | Jrryjms07 (08-14-2014) |
#119 |
Drives: 2014 WRB BRZ
Read the OP, that's just crappy, sorry to hear. Didn't get to read all the rest yet, but Which dealership was this at in Houston? As a H-town native I would like to know for future reference, as would others I'm sure.
#120 | |
Drives: 2014 BRZ Limited
People used to use ATF to clean out high mileage engines in the days when motor oil lacked the detergents we have today. My grandfather used to do that. One quart mixed in with the regular motor oil would do the trick, and you didn't do it every oil change. You only did it after tens of thousands of miles. You certainly didn't fill your whole crankcase with it and run the engine with no oil, not even for 20 miles. Now think about that for a minute. One quart diluted in four or five quarts was enough to clean out the gunk that had built up with 1960s or 1970s era oil after 60K or 80K miles. That should give you an idea of how caustic this detergent is. The problem for the OP is that the engine didn't grenade. What I would be afraid of instead is that the engine was subtly damaged so that performance will degrade over time, which would be difficult to make a claim for. Even if he took the 100K mile warranty, that wouldn't help him if the engine just wasn't running at its highest efficiency and was vaguely sluggish, or just "not quite right." It also doesn't help him if the car really should last 250K miles and it grenades after 101K. If I were the OP I would want to unload this car and get a replacement that I could be confident in. It wouldn't be honest to sell this car to someone else without disclosing the ATF incident, and it's going to be difficult to sell it if it were disclosed. Therefore, to be fair, the dealership should assume that responsibility by buying the car back from the guy and finding him a replacement. At 8400 miles, I don't think it's unreasonable for that replacement to be new. Then, once they've taken the damaged car back, they can sell it and either be the dishonest ones or take the loss if they're not. |
#121 |
It's not like something with no lubricating properties was put in the engine. Unless the ATF has some affect on the seals, I say no damage was done with as few miles driven.
A guy I used to work for at a small German repair shop used to fill old engines with ATF and run them for a few days to clean the sludge. Those cars all survived with no issues. Someone here posted that ATF is the same viscosity as 0-20 |
#122 | |
Drives: 2013 GBS BRZ Limited
But WAIT! I bought my BRZ used and it had 9000 miles on it...... I wonder if it had an ATF "flush" as well? |
#123 |
Drives: 17 Alfa Romeo 4C
Regardless if the engine is damaged or not .... you can see that the majority of forum members agree that the engine is damaged somewhat. This is the perception right or wrong. When it comes time to sell this car ... the car's value will be reduced. The dealership needs to understand this diminished value that they placed onto the OP. Extended warranty does nothing for the perceived diminished value unless OP plans on keeping the car past 100K miles (not realistic). The dealership needs to make this right.
#124 |
Drives: 13FR-S
#125 |
#126 |
Drives: 2015 FRS
I did misread (and misquote) the question. The guy I sourced was asking if his engine would have been damaged by adding some ATF fluid to his existing motor oil. It was not a case where the crankcase held nothing but ATF. I stand corrected.
I had a chance to roundtable the issue with the owner of a respected indie shop here and a couple of his techs. All were fascinated as to how the shop managed to screw up an oil change so badly. That aside, the consensus was that if the duration was short, and the owner saw no smoke and didn't get an oil pressure light, no permanent harm done. ATF is not the right petroleum based lubricant for an engine but it is still a petroleum based lubricant. I asked about the wisdom of pulling the heads and inspecting the cylinder walls for scoring or burning. The consensus here was that the engine is so precisely built with such tiny tolerances, opening it up for exploration would probably result in more issues than the ATF mistake caused. They stated if the engine was torn down you'd likely find it to be unusually clean but undamaged. With respect to mitigation and the owner's understandable anxiety, they felt that complimentary oil changes and the extended warranty were appropriate. The shops owner addressed the issue of getting bigger damages ( a new engine, a replacement car). He pointed out that no dealership or shop is going to voluntarily replace an engine or buy back the car because that remedy is so disproportionate. A law suit would be required, and he felt that the mediator and the judge would find the extended warranty to be fair compensation. With respect to future work, the consensus was that the OP's car was going to get the star treatment here on out and is probably the safest place for future oil changes and general maintenance.
| Dealer Service Center Oil Change Nightmare | FRS-Texas | Engine, Exhaust, Transmission | 28 | 08-15-2014 04:27 PM |
| Dealer service 5/13.... | Tromatic | Software Tuning | 4 | 05-13-2014 02:26 AM |
| Best Scion service center in LA area? | G.I.Choe | Southern California | 12 | 04-18-2014 11:47 PM |
| First Dealer Service | Umbie | BRZ First-Gen (2012+) — General Topics | 7 | 12-12-2012 09:50 AM |
| First Engine Oil change, DIY or Service? | davey90 | AUSTRALIA | 25 | 09-13-2012 01:56 AM |
