#29 |
Drives: FRS
Not this again!
I researched this feverishly a few months back. I started a similar thread that induced a lengthy debate. As always with this topic, no one agreed on anything. Here is my opinion: Despite what others may say I believe the crank shaft pulley IS in fact a harmonic dampener (NOT a harmonic balancer). The debate over this will never be settled. What I think most of us can agree on, however, is that the performance benefits of a new crank pulley are marginal at best. When we weigh the possible costs against these marginal gains it seems apparent that a pulley simply isn't worth it. Despite what you believe why would you put your engine at risk (even if only perceived) for what amounts to very minimal benefit? My 2 cents... |
#30 |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#31 |
Troll Hunter
Drives: fr-s, tundra
Biggest con seems to me is that your wallet is now lighter.
waste of $ imo
#32 |
Thanks
Part of the weight savings brah!
#33 |
Troll Hunter
I should be a part of the weight gaining club. I'm not good at weight savings on the car
#34 | |
Thanks
#35 |
Marginal gains for marginal money, doesn't seem like that bad of a deal to me. Guess it all comes down to what you want to accomplish with your build. Going FI or staying stock, then ya it's kinda worthless. Trying to squeeze out every last bit of power from a NA setup in conjunction with a CF driveshaft, lightweight rotors and wheels then it might be worth it
#36 | |
Because compromise ®
Drives: Red Herring
Same ol' same ol'.
Yeah, I'm quoting myself. Quote:
That's weird. I seem to have got the possible powa increase mixed up. 47GW or 40 megaWatts is still a metric truck load. You would be better off using imperial measurements because then you would have even more powa.
#37 | |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
On my own AT cars I run a LWCP. On my MT cars I run a LWFW. |
#38 | |
Yes. My own AT cars. Due to electronic throttle and tuning there is always a sweet spot for cruising MPG. Find the sweet spot and with a LWCP you can gain 1-2 MPG cruising. Its not that easy to drive in the sweet spot (it takes some modulation) and its not any fun. So, 99.97% of owners never realize it. They are not putting go fast parts on the car and then not using the throttle. |
#39 | |
On forced induction cars running all 3 LW pulleys we have seen issues with load changes that cause idle stumbles/stalls. |
#40 | |
#41 | |
#42 | |
Drives:
| Light weight flywheel and crank pulley? | wootwoot | Engine, Exhaust, Transmission | 133 | 06-23-2015 01:04 PM |
| Light Weight Pulley's | exam2300 | Engine, Exhaust, Transmission | 18 | 02-08-2014 12:02 AM |
| FS:PERRIN Light weight pulley NEW $85 Shipped | Amalgamo | Engine, Exhaust, Bolt-Ons | 1 | 05-01-2013 11:10 AM |
| FS - Agency Power Light Weight Pulley | Kochinopride | Engine, Exhaust, Bolt-Ons | 3 | 11-12-2012 05:32 PM |
