Old 07-31-2014, 02:40 PM   #29
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Originally Posted by mav1178 View Post
It doesn't.
This item is meant for drifters, for instant throttle response. It was born out of Japanese drifting.
-alex
No, it's actually not. It started way before that. They're very common on muscle cars. I never ran one in my GTO but plenty of people did. And Camaros, Mustangs, etc. It's far more common on high horsepower V engines than in imports I'd gather given everyone's lack of familiarity around here.
The idea is, you are preventing the energy generated by the engine from being wasted twisting the engine on its mounts rather than twisting the transmission/driveshaft. It's a tiny gain in efficiency of the drivetrain. Also, it helps to increase the longevity of the engine mounts as the forces they're subjected to are correspondingly reduced.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 07-31-2014, 03:30 PM   #30
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I don't get whats the fucking hate here. I think camber hellaflush the fuck out of everything, I was asking why they don't exist for our cars and if they would have an usage or not. I didn't talk about adding stickers bomb to my car or plastidipping it, Jesus people need to chill the fuck out sometimes. Thanks to those who actually provided answer, and that' s even aimed at you, @jsimon7777 even if your shit was full of sarcasm.
/end of thread
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 08-04-2014, 08:53 PM   #31
emirdtm
Drives: Toyobaru
/end of thread
My friend I completely agree with you I have cusco engine mounts Perrin trans mount whiteline diff mounts and there is still a shit load of engine movements the first company that makes a engine damper for this car I will buy it I don't know what's wrong with ppl when you actually asked them a very good question they start being smart like they know everything.
emirdtm is offline   Reply With Quote
Old 08-04-2014, 09:23 PM   #32
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
But what negative effects are you seeing from the engine moving slightly?
The torque damper for fwd makes sense because it reduces wheel hop. Engine movement has nothing to do with wheel hop on a rwd. Diff movement does. So maybe a diff torque damper would be what you need.
Not hating just explaining.
jebuwh is offline   Reply With Quote
Old 08-04-2014, 09:28 PM   #33
Hot Lava
The Antiriced
Hot Lava's Avatar
Drives: women wild
Ya, this. It was common for high HP engines to demolish motor mounts. If you want to be old school about it use a chunk oh chain.
/end of thread
Just thanking the people who vindicated your original question would have been full of win. This, not so much.
Hot Lava is offline   Reply With Quote
Old 08-04-2014, 11:01 PM   #34
Tromatic
Edited.
Old 08-04-2014, 11:22 PM   #35
emirdtm
Drives: Toyobaru
Feel and responds with solid engine mounts the engine feels like it's welded to the frame... Yeah there is a lot of vibration but I don't mind it coming form a EK with B18C5 with Hassport mounts and a S2000 with evasive mounts maybe that will explain!
Old 08-04-2014, 11:40 PM   #36
Tromatic
So half the people here are talking about reducing the transfer of engine torque to the frame/chasis of the car, and the other half are talking about increasing transfer of engine torque to the frame/chasis? I will be selling a torque-equalizer soon for the FR-S. It does everything.
The Following User Says Thank You to Tromatic For This Useful Post:
jebuwh (08-04-2014)
Old 08-04-2014, 11:49 PM   #37
jebuwh
Village Idiot
jebuwh's Avatar
I'll take 2 please.
Old 08-04-2014, 11:55 PM   #38
stugray
Drives: 2013 GBS BRZ Limited
So, why doesn't the FRS have one? Because a flat four engine simply does not generate that kind of force, it's 'balanced' so they say.
You got everything perfect except I have an issue with this one statement.
Boxers are "Internally balanced" in that the layout of the engine is inherently opposed so like forces cancel
When a cyl hits TDC on one side, another hits TDC on the other side so a lot of the forces that contribute to vibration cancel.
In a straight or V configuration, they do not totally cancel.
The Torque damper cancels net torque on the motor due to the acceleration of the rotating mass (crank, rods, pistons, FW, CLutch, Accessories, drivetrain etc).
This will apply a torque to ANY engine that has a single output shaft.
So yes, we COULD use torque dampers on our engines AND our diffs if anyone made them.
Anyone who has seen the twisted chassis of most 70s ford pickups can imagine the torque that the engine applies to the chassis every time you step on it.
I think our engines are just low enough output (stock) to not need any damp(en)ing except the motor mounts.
Old 08-04-2014, 11:57 PM   #39
Simon99
Simon99's Avatar
So following that though, a stronger differential mount/damper would be more useful
Old 08-01-2015, 03:39 PM   #40
deafwiggle
deafwiggle's Avatar
Drives: '14 Scion FR-S; '93 JDM MR2 T
I'm a bit late to this thread, but feel it could use some reinforcing:
This^^^ I'd be in for both engine and diff dampers. My FR-S has a very clear delay between engine ac/decelerating, and the wheels ac/decelerating; I can literally feel everything winding up before the car responds. Working on getting/installing stiffer bushings when/where available...
'14 FR-S; '93 JDM MR2 T
Rippin' it. ...old and new school
deafwiggle is offline   Reply With Quote
Old 03-05-2023, 09:55 AM   #41
Darknd666
Drives: 2017 86
Silk Road Torque dampener for ZN6
https://www.rhdjapan.com/silk-road-s...c6-86-zn6.html
I discovered this, which is exactly what you were asking about. I cant seem to find how it installs though, i imagine it connects the engine to the top of the strut tower based on the image of the parts. This would dampen the side to side movement that these engines encounter when revs are applied heavily.
Darknd666 is offline   Reply With Quote
Old 03-05-2023, 11:23 AM   #42
WNDSRFR
Drives: FR-S,GTI
God
There's soo much torque. How can I dampen it?
Sorry, couldn't help myself.
The Following User Says Thank You to WNDSRFR For This Useful Post:
NoHaveMSG (03-05-2023)
Damper rates mikepaul21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-03-2014 09:23 PM
Engine Power Delivery - Torque Vs. Horsepower whataboutbob Forced Induction 1 07-22-2013 09:39 PM
Engine Pulley Torque Requirements JDKane527 Engine, Exhaust, Transmission 6 03-22-2013 08:24 PM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 11:52 PM
