View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 07-26-2014, 06:26 PM   #197
DRACHENV6
Drives: tata nano
Originally Posted by Sellout View Post
Look through that list above and try to find an example of overboost caused by failure of the wastegate.
That doesn't really matter. Preventing knock is all in the tune. Even a bad N/A tune can rattle the motor with knock and spin the bearings(or worse).
I've seen built race engines with fully forged bottom ends come apart due to knock with less than 200 ft lbs at the flywheel.
Whats the purpose of a WG?
DRACHENV6 is offline   Reply With Quote
Old 07-26-2014, 07:02 PM   #198
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://forums.nasioc.com/forums/show....php?t=1029957
Old 07-26-2014, 07:05 PM   #199
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Neal@EQtuning View Post
In the last 6 years our shop has built over 600 EJ's, and 99% were built because of failure. The other 1% were preventative. Ejs have what we like to call "glass pistons". From what we've seen already, the FA20 is a much stronger engine.
Although the semi closed design was in good practice, the hypereutetic pistons werent cast properly, and yes came the term glass pistons. Also known for ringland snapping and such. The only advantage the EJ has over the FA is the amount of crankcase oiling it can do. Unfortunately the FA wasnt built for that extra 10-20 PSIa.
Old 07-26-2014, 07:21 PM   #200
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
What's the purpose of a forum member who's "never boosted" saying something like "correct me if I'm wrong..." and then trying to argue an incorrect assumption with someone who actually knows a bit about the subject in question?
Operator error does not constitute wastegate failure. They really are pretty reliable.
Sellout is offline   Reply With Quote
The Following 2 Users Say Thank You to Sellout For This Useful Post:
Manji (07-26-2014), s2d4 (07-26-2014)
Old 07-26-2014, 07:28 PM   #201
D K
Stig's dark passenger
It's actually not uncommon.
Knock creates intense combustion chamber pressures, which dramatically increase the pressure on the rod bearings, the oil gets squeezed out and you have metal to metal contact, bearing spins.
I suppose it's possible, but more likely than not, a spun bearing is due to lack of oiling or possibly even the wrong type of oil.
What oil was he running when he spun the bearing?
Hopefully not the junk they put in the cars at the factory????
D
D K is offline   Reply With Quote
Old 07-26-2014, 07:40 PM   #202
Sellout
Mr. Cranky Pants
Sellout's Avatar
D
It's more than possible. It is literally one of the most common causes. Look it up if you have to, I'm not making this up...
Old 07-26-2014, 10:36 PM   #203
s2d4
s2d4's Avatar
Win at internet bro.
The Following User Says Thank You to s2d4 For This Useful Post:
raven1231 (07-27-2014)
Old 07-26-2014, 10:41 PM   #204
loogs
Drives: on cruise control
so basically if you get an STi, keep it to bolt ons and such? also, whats the deal with this great FA20 motor? so the compression ratio is too high and thats why they blow? then i dont understand whats the deal with the new WRX. isnt that a FA20 with a turbo? why is that safe? and if thats the case then wouldnt the best engine swap for an 86 be that exact motor, the FA20 DIT??
loogs is offline   Reply With Quote
Old 07-26-2014, 10:42 PM   #205
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Days of explaining needed to bring you up to speed. Search fool.
The Following 4 Users Say Thank You to Reaper For This Useful Post:
ATL BRZ (07-30-2014), Darryljr11 (07-27-2014), s2d4 (07-27-2014), The Racers Line (07-27-2014)
Old 07-27-2014, 08:21 AM   #206
Reaper
Reaper's Avatar
Drives: violent
The fa20 is the strongest smartest engine Subaru has ever built. The fa20dit in the wrx is lower compression, turbo and uses a less sophisticated injection system.
The ej in the sti is poop and blows up. Fullblown made more hp on a stock fa20 then some built ej's can handle.
There are probably 15 threads on fa20dit swaps. Its worthless. It won't fit. It has a crappy turbo and intercooler and doesn't have the port injections system which I think will be the downfall in 5 years like every other di only car on the market thats been a catastrophe. You will see fa20 4d-s swaps into wrx's I guaranty it.
Fa20s are blowing up from user error or abuse. 400whp on e85 is getting more and more common on a stock engine.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
Sportsguy83 (07-27-2014), woode (07-27-2014)
Old 07-27-2014, 12:16 PM   #207
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
This. I laugh at the people who start talking about swapping in an EJ..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 07-27-2014, 09:51 PM   #208
nelsmar
Originally Posted by dwx View Post
He has another thread and is doing a LS swap now, but I can't find it. It sounded like he had a cam failure of some sort, not a bottom end failure.
No one ever opened the block up. The car still ran but it ran very poorly last I heard. My friend now has the engine and we were going to tear it down and see what let loose soon. Its just too damn hot out right now in Phoenix to be doing a detailed tear down. I haven't seen the logs or talked to mike but from talking to @Cross and a mutual friend it sounds like something else may have caused the failure and not the tune. VVT is possible, or about 1,000 other failure points. hah
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Reaper (07-28-2014)
Old 07-27-2014, 09:52 PM   #209
nelsmar
I hate when people ask me why I didn't just swap in an EJ... SMH
Old 07-28-2014, 11:10 AM   #210
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would feel more safe with a properly boosted BRZ/FR-S FA20 at 300 to 400 whp then I would with an EJ25. I am an admin in the local Subaru club, and I have seen how many EJ motors have required rebuilds.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
Dipstik-sportech (07-28-2014), loogs (07-28-2014), Reaper (07-28-2014)
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 02:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 03:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 10:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 07:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 11:53 AM
