#29 |
NASIOC: AzNSTiImpreza
Got my fuel pump replaced at the dealer last week... 500 miles later crickets are back
#30 |
Many people have reported that a tiny amount of 2 stroke oil helps get rid of the crickets.
Do a search here, there's a couple threads about this. |
#31 | |
Drives: '13 FR-S Argento
I had the pump replaced under warranty at my 15k service, and the chirps went away, but they returned after about 2000 miles. I'll have to learn to live with it or get a louder exhaust
.Quote:
| The Following User Says Thank You to madboom For This Useful Post: | JonAvalon (05-19-2014) |
#32 |
SCBYD0
Drives: 18 BRZ (WRB)
#33 |
Drives: 2014 Subaru BRZ Limited CBS
#34 |
It's not gonna fix anything. . my crickets came back writing 1000 miles of replacing
#35 | |
Drives: 2014 Subaru BRZ Limited 6smt
Has anyone else noticed that their crickets went away after driving the car for longer? |
#36 |
Drives: 2014 BRZ Limited
The gas blend being dispensed by the gas station you use has probably changed. Once summer is over and they change their blend again, they'll probably come back.
#37 |
Drives: 2015 WRX
I thought it was pretty much proven that ethanol has absolutely nothing to do with the crickets. Given the fact that people have no crickets running E85 and some still have them running pure gas pretty much confirms the fact that its something else other than gas formulation.
#38 | |
#39 | |
They also put additives in the gas that are alleged to clean and protect your engine and fuel system. I'm convinced it's those additives that are contributing to the chirping problem. More than likely most of the E85 gas doesn't have those chemicals, which is why some people see their crickets disappear when they go over to E85. Likewise, E0 is not top tier gas in the US, because to qualify as top tier gas it must have ethanol. So when you get ethanol-free gas, you're getting lower tier gas that also may not have all those fancy additives alleged to protect your engine. Without those additives, many people lose the crickets and think the lack of ethanol did it. It would be great if we could isolate exactly what is being put into the gas that's causing the chirp, then find a way to counteract it. But there are about 2 dozen basic gas blends in use in the United States, not including all the variations in concentrations introduced at different refineries and different distribution centers around the country. The supply chain adjusts to demand and individual refinery output, so that a single station can't guarantee that the gas you buy this week is the same formulation as what you bought there last week. Whenever I see someone post that his crickets went away, I have to suspect that something changed in his regular station's supply chain to remove whatever was making the crickets happy. |
#40 |
Drives: 2014 FRS Monogram Whiteout
I had the crickets last September when purchased. At around 2,000 miles, I did a few mods with a CAI, headers, cat back and ECU-Tek/tune. Haven't heard a cricket since. Runs like a swiss watch with satisfying power.
| CRICKET FIX! | alex_86 | Issues | Warranty | Recalls / TSB | 142 | 12-04-2013 12:29 PM |
| Took my car to the dealership concerning the cricket noise. | Ludacrits | Issues | Warranty | Recalls / TSB | 6 | 10-14-2013 04:18 AM |
| Chirping/Cricket Fix Out? | deeranged | Issues | Warranty | Recalls / TSB | 15 | 10-02-2013 06:43 PM |
| Cricket TSB | [deleted] | Southern California | 25 | 06-05-2013 07:01 PM |
| New trans, window, and cricket fix! | foney_email | Issues | Warranty | Recalls / TSB | 11 | 03-14-2013 06:35 PM |
