Old 04-06-2012, 01:15 PM   #15
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Originally Posted by brzmaybe View Post
I'm trying to get my head around this one...
If the additional bolt is offered by Scion as an alternative part for the 2013 FR-S, then it (and its resulting alignment change) IS legal for SCCA stock autocross for the FR-S.
HOWEVER.... if Subaru does NOT offer the same part within its part catalog for the 2013 BRZ, then the part IS NOT legal for SCCA stock autocross for the BRZ, even though it's a form/fit/function replacement?
Your understanding matches mine and others I've read. However, I'm not affiliated with the scca in any way, so [insert your favorite pithy disclaimer here].
For those of us wanting to autocross in a stock class, this is an interesting situation. These are the sorts of gotchas you wouldn't want to learn AFTER you'd bought your car.
I'm hedging my bets having placed an official BRZ order and also being 'on the list' at the local Scion dealership - with careful explanations to both that I need to see the respective FSM's before making a final purchase decision.
jdrxb9 is offline   Reply With Quote
Old 04-10-2012, 08:13 AM   #16
Future
Future's Avatar
Drives: BRZ!
On another note, where is the PDF ?
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 04-10-2012, 05:59 PM   #17
dsgerbc
Drives: BRZ(sold), STI
+1 to those begging for a PDF. Via PM works too
Pretty please.
Old 04-10-2012, 06:26 PM   #18
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Every time I see a new post in this thread, I would come in and check for the pdf. So far still disappointed
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 04-10-2012, 06:28 PM   #19
OrbitalEllipses
Drives: Attitude
+infinity on the .pdf
I did notice that Toyota's 2 day account is far cheaper than Subaru's.
Old 04-15-2012, 06:20 AM   #20
taosracer
Frickin' Genius
taosracer's Avatar
Drives: GBS BRZ 6sp, 2002 ts wagon WRX swap
Just checked STIS, no shop manual yet....
taosracer is offline   Reply With Quote
The Following User Says Thank You to taosracer For This Useful Post:
ft86Fan (04-15-2012)
Old 04-15-2012, 11:06 AM   #21
Toyota fr-s
Yes, Toyota fr-s
Drives: 1991 MR2 Turbo T-Top, Gen3 3SGTE
Electrical wiring in PDF please!!!
Toyota fr-s is offline   Reply With Quote
Old 04-18-2012, 09:41 AM   #22
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Jeff, can you possibly use your access to the parts catalog to answer 2 questions?
Does the Canadian version of the car come with a TPMS? (They can be a pain with winter tires, you either live with the warning light or have to pay a dealer to reset it if you have sensors inserted in your winter rims, unless Toyota has used a system like Porsche's which can recognize a second set of wheels.)
And what is the diameter of the lug nuts (need a socket head for wheel swapping)?
Sport-Tech is offline   Reply With Quote
Old 04-18-2012, 11:19 AM   #23
DOTman05
Drives: Evo 8
I have TIS as well never posted a PDF but i'll try anyone need any other PDF's?
DOTman05 is offline   Reply With Quote
Old 04-18-2012, 12:51 PM   #24
MPot
Drives: SSC #79
The big question for me is, has there been a TSB released that shows "Crash Bolts" for both the Scion on the Subaru.
I haven't been following every new Toyota, but from what I remember most Toyotas (even the Previa) and Scion with struts was noted as being able to use them.
(This is important to anyone who wants to run in SCCA solo stock class.)
Thanks!
Mike
MPot is offline   Reply With Quote
Old 04-18-2012, 01:14 PM   #25
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
It looks like yes, it does.
I don't have that information, but I'd guess it's going to be the same as Subaru normally uses, which is probably 19mm (most Toyotas use 21mm).
Thanks!
Mike
This was already covered in another thread, but if you need to adjust camber, you can replace the upper bolt with the same bolt that the lower one uses and get adjustment that way.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
Sport-Tech (04-18-2012)
Old 04-18-2012, 02:35 PM   #26
MPot
Drives: SSC #79
Thank you, I did find that thread about switching the bolts.
But I'm hoping that Toyota will offer completly different bolts. For example, when I was running my 2nd generation MR2, Toyota had a TSB that allowed you to use any of three different size bolts. I actually ran 2.8 deg negative camber, in the front of the MR2.
I was just trying to see if anyone who worked at a dealership had seen anything yet.
Thanks,
Mike
Old 04-18-2012, 05:06 PM   #27
Jeff Lange
Jeff Lange's Avatar
No, there isn't anything like that listed yet, and I have a feeling there probably won't be, but I can't say for sure.
Jeff
Old 04-18-2012, 06:25 PM   #28
jdrxb9
jdrxb9's Avatar
Mike,
It is my understanding that Toyota has been putting their 'crash bolt' documentation (probably should really be called camber adjustment bolts) right in the service manual for a while now.
You can see a good example in the '05 Scion TC manual over on scionlife: http://www.scionlife.com/tech/manual/?manual=tc05_0001
As Jeff noted, the info in the service manual and also the info that Jeff provided elsewhere (link) that each bolt callout only references one part number seems to indicate we're stuck with relatively little adjustment.
However, I'd love to see any info on relatively recent Toyota crash bolt TSB's (for any model) if you've got it!
Standard Features now posted on Scion.com Linseal Scion FR-S / Toyota 86 GT86 General Forum 40 09-15-2012 03:02 PM
Scion FR-S VIP video (posted by scion canada) Saibot CANADA 5 03-09-2012 12:15 PM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
2013 SCION FR-S Safety Audi Scion FR-S / Toyota 86 GT86 General Forum 14 01-17-2012 08:29 PM
Road & Track Scion FR-S review posted. ZZ-FRS Scion FR-S / Toyota 86 GT86 General Forum 26 12-10-2011 11:35 AM
