Old 04-05-2012, 12:27 PM   #1
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
2013 Scion FR-S Information Posted to TIS
If anyone has a TIS account, you can now read the repair manuals, new car features book, etc.
It's all loaded.
Neat.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 04-05-2012, 12:31 PM   #2
feedbag
Seasoned Spirit
Drives: 2013 DGM BRZ Premium
You know what to do.
feedbag is offline   Reply With Quote
Old 04-05-2012, 02:37 PM   #3
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
So what does the alignment proceedure look like? Any info on the range of adjustment that can be obtained?
jdrxb9 is offline   Reply With Quote
Old 04-05-2012, 02:45 PM   #4
Jeff Lange
Jeff Lange's Avatar
I checked earlier, I'll look again.
The front is adjustable, you can gain adjustment by ordering lower bolts and using them to replace the top bolts. I'll check the exact specs.
There were a couple other pieces of interesting information that I came across during looking as well. I don't really have the time to upload all of it, but I'm sure someone will at some point (perhaps me, later, if nobody else has).
Originally Posted by Scion FR-S Repair Manual, Front Wheel Alignment
The range that can be adjusted by replacing bolts is 0°+/- 45' (0°+/- 0.75°).
Jeff
Old 04-05-2012, 03:54 PM   #5
jdrxb9
jdrxb9's Avatar
Jeff - thanks for the info. I have a standing request with my scion sales guy to get me a peek at the manual when available, but who knows when that might happen!
"(0°+/- 0.75°)" - Not sounding very good for scca stock autocross performance or tire life.
Old 04-05-2012, 04:12 PM   #6
Racecomp Engineering
So that adjustment requires replacing the OEM bolts....that doesn't sound stock class legal?
For everyone else it's a must do ultra cheap modification IMO but it sounds like stock class autocrossers may be unlucky.
- Andrew
Old 04-05-2012, 04:25 PM   #7
MiguelAE86
Drives: NB Miata
someone PLEASE get a PDF
MiguelAE86 is offline   Reply With Quote
Old 04-05-2012, 04:29 PM   #8
jdrxb9
jdrxb9's Avatar
You are replacing one OEM bolt with another OEM bolt. As long as the bolt you are using is 'offered' by the OEM, it is scca stock legal, and it will not be questionable at all with the procedure called out in the FSM.
Old 04-05-2012, 05:02 PM   #9
It's OEM but for a different car (Impreza) is my understanding. Available from the dealership but not included with the car from the factory.
I'm admittedly far from being on top of these kinds of details on classing.
- drew
Old 04-05-2012, 05:12 PM   #10
Jeff Lange
Jeff Lange's Avatar
It's from the FR-S. It's the same as the lower bolt, and is intended to be used by Toyota/Subaru to adjust the camber if required (stock or not).
Jeff
Old 04-05-2012, 05:13 PM   #11
Ahhh so the replacement bolt is not a cam bolt, just a different size?
Old 04-05-2012, 05:30 PM   #12
Jeff Lange
Jeff Lange's Avatar
Seems to be, yeah.
Jeff
Old 04-05-2012, 05:40 PM   #13
jdrxb9
jdrxb9's Avatar
The rules: http://www.scca.com/assets/2012_Solo_Rules_March.pdf
Specifically section 13.8 on pages 77 and 78.
"If offered by the manufacturer for a particular model and year, the use of shims, special bolts, removal of material to enlarge mounting holes, and similar methods are allowed and the resulting alignment settings are permitted even if outside the normal specification or range of specifications recommended by the manufacturer."
So as long as the OEM offers specific parts to be used to adjust alignment on a specific model/year, it is legal. That it is apparently called out in the FSM makes it even more clear.
Note that I'm not defending the rule as sensible, just pointing out the way it is.
Old 04-06-2012, 12:41 PM   #14
brzmaybe
Drives: Subaru
I'm trying to get my head around this one...
If the additional bolt is offered by Scion as an alternative part for the 2013 FR-S, then it (and its resulting alignment change) IS legal for SCCA stock autocross for the FR-S.
HOWEVER.... if Subaru does NOT offer the same part within its part catalog for the 2013 BRZ, then the part IS NOT legal for SCCA stock autocross for the BRZ, even though it's a form/fit/function replacement?
For those of us wanting to autocross in a stock class, this is an interesting situation. These are the sorts of gotchas you wouldn't want to learn AFTER you'd bought your car.
I got caught in an analogous gotcha with an NC MX-5. Got the car to do some track days, only to find that the factory roll bar wouldn't qualify as roll protection... and it was quite some time before the aftermarket figured out how to do a qualified bolt-in replacement for the factory unit.
brzmaybe is offline   Reply With Quote
Standard Features now posted on Scion.com Linseal Scion FR-S / Toyota 86 GT86 General Forum 40 09-15-2012 03:02 PM
Scion FR-S VIP video (posted by scion canada) Saibot CANADA 5 03-09-2012 12:15 PM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
2013 SCION FR-S Safety Audi Scion FR-S / Toyota 86 GT86 General Forum 14 01-17-2012 08:29 PM
Road & Track Scion FR-S review posted. ZZ-FRS Scion FR-S / Toyota 86 GT86 General Forum 26 12-10-2011 11:35 AM
