Old 07-11-2014, 08:46 PM   #15
CSG David
CSG David's Avatar
Originally Posted by ddeflyer View Post
yeah, originally I choose the compound distribution because I didn't think I would be going pretty much every other weekend and I wanted to keep the noise and dust more in check. I was figuring that the rear brakes would be more work to swap than the fronts so I just kept with one compound for the rear. Then I kind of stopped swapping the pads and after mucking up some rotors in the process I realized that I should be swapping rotors also which was alot of work :p
I'm not yet doing the pedal dance but it is something I want to move up to; so far I have only tried it on some autocross runs.
Pedal dance nao.
Old 07-12-2014, 12:36 AM   #16
wheelhaus
wheelhaus's Avatar
I'd recommend you use the same compound front/rear. You're probably noticing that the fronts wear faster than the rear; that's because theyre doing more work. You want to distribute the work as best as you can to even out the wear.
From everything I've read, same compound front and rear is ideal. Mixing compounds does change braking torque, but will be inconsistent through usage at different heat levels, pedal pressures, etc, so braking balance front and rear isn't exactly balanced and linear.
If you're not doing the pedal dance, then the ECU is distributing the brake force as best as it can for you automatically.
Are you certain the EBD is actively changing pressures front and rear? I thought line pressures were fixed, and EBD only activated single lines in response to some loss of stability such as an imminent spin, ABS activation, etc (with the VSC on at some level).
Old 07-12-2014, 02:46 AM   #17
CSG Mike
CSG Mike's Avatar
If you're threshold braking, it is working.
Old 07-15-2014, 08:36 PM   #18
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by dradernh View Post
It's all relative. Some drivers go once or twice a year, and some are out there 40-50 or even more days a year.
I meant 16 days on a set of pads.
The Following User Says Thank You to Pat For This Useful Post:
dradernh (07-16-2014)
Old 07-15-2014, 10:35 PM   #19
CSG Mike
CSG Mike's Avatar
It really all depends on the driver and conditions. E.g. a more experienced driver on stickier tires on a brake heavy track will go through pads faster.
wparsons (07-16-2014)
Old 07-16-2014, 12:00 AM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
sup.
16 track days is a LOT.
Eh, I got at least that many and ~26,000 miles out of a set of Carbotechs.. and they still have a ton of life left in the back. I switched to Project Mu 999's just to make F&R the same material.
In my experience, these cars don't use much rear pad with TCS/VSC off.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-16-2014, 12:39 AM   #21
Pat
Pat's Avatar
Drives: 2023 BRZ
hmmm... My front DTC-60s will last about 7 or 8 NASA track days. Car has had A/S and summer tires but is otherwise stock. Rears last twice as long.
Old 07-16-2014, 02:15 AM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Still not bad wear, but I've definitely had less overall. I'd guess I could get 20-25 days out of the 999s in the back. How knows on the front, I don't run the front OEM brakes so I have yet to wear a set of front pads, I get bored and want to test a new compound before they are anywhere near dead.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
CSG Mike (07-16-2014), wparsons (07-16-2014)
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 03:23 PM
rear brake noise norcal_brz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-19-2013 04:25 PM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 03:39 PM
rear brake pads donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-05-2013 11:43 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
