Old 07-13-2014, 09:42 AM   #8877
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Trans and diff fluid changed yesterday with Motul 300 @ 29k miles. The fluid that came out of both looked good, it was a nice gold color. The drain plug for the diff was loaded with metal as I expected. Trans drain plug wasn't that bad.
B-R-Z is offline   Reply With Quote
The Following 2 Users Say Thank You to B-R-Z For This Useful Post:
chanomatik (07-13-2014), Ganthrithor (07-14-2014)
Old 07-13-2014, 09:44 AM   #8878
zinzan
zinzan's Avatar
Drives: Subaru BRZ 2014 Limited WRB
Took it into the dealership for some work yesterday.
Head Unit suddenly died last month - replaced under warranty (but noticed when I got home that it has "remanufactured" stickers on the back).
Driver's side headlight had some kind of water stain on the inside, noticeable under certain lighting conditions at certain angles - replaced under warranty.
Installed a Mini 0803 dashcam, running the wires under the headliner and passenger A pillar, behind the dash, and into the glove compartment power socket. Nice and clean.
Plan to wash and polish today.
zinzan is offline   Reply With Quote
The Following User Says Thank You to zinzan For This Useful Post:
Old 07-13-2014, 10:32 AM   #8879
skeet
Drives: 2015 BRZ
Yesterday I took my new BRZ with 8 miles on it and stuffed it with my six dogs and two ducks. 300 miles later and it is full of fur and feathers. I love this car and now it smells like it.
skeet is offline   Reply With Quote
The Following 2 Users Say Thank You to skeet For This Useful Post:
chanomatik (07-13-2014), Evil Jesus (07-13-2014)
Old 07-13-2014, 10:56 AM   #8880
Shedd22
BAMF
Shedd22's Avatar
Drives: 2014 SWP BRZ
Curious as to why...and how you had the need to put six dogs and two ducks in your brand new car?
Shedd22 is offline   Reply With Quote
Old 07-13-2014, 11:18 AM   #8881
skeet
Drives: 2015 BRZ
Went out of town for the weekend.
Old 07-13-2014, 01:01 PM   #8882
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Got new rubber yesterday in the form of Continental ExtremeContact DW 245/40. Put them on without spacers and the tire rubbed the spring perch (due to -1 degree camber). Added a 3mm spacer and it was super close, so I swapped up to 5mm and feel much better about it.
Maybe the tires are a bit over-inflated, but the steering has a really "light" feeling. Could also be the super deep tread being a little more squishy than the MPSS I removed.
I also installed Whiteline KDT925 - Diff cradle and outrigger inserts. Easy install and did you know they're black now?? Blew my mind, I liked the little hints of yellow but the diff cradle inserts always looked a bit awful, so black is a good move.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
Old 07-13-2014, 02:29 PM   #8883
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
LED Fog Lights. Uniform color yay!
And I couldn't be more pleased with a $6 eBay purchase.
Candlejack is offline   Reply With Quote
The Following 5 Users Say Thank You to Candlejack For This Useful Post:
BirdTRD (07-13-2014), chanomatik (07-14-2014), Ganthrithor (07-14-2014), Odd (07-14-2014), sprintertrueno86 (07-13-2014)
Old 07-13-2014, 02:34 PM   #8884
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Awesome pictures, @chanomatik
What are you shooting with?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 07-13-2014, 05:13 PM   #8885
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
Originally Posted by Candlejack View Post
Thanks man, I followed the link and just ordered a pair too. Did it require any thing other then swapping them out?
Also new exhaust!!
And rain..
jimmillion is offline   Reply With Quote
The Following 2 Users Say Thank You to jimmillion For This Useful Post:
Ganthrithor (07-14-2014), Shedd22 (07-14-2014)
Old 07-13-2014, 06:57 PM   #8886
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
hello, noob here.
do you have some links i should read up before i tackled these fluid changes?
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 07-13-2014, 07:03 PM   #8887
B-R-Z
B-R-Z's Avatar
Originally Posted by wrb View Post
hello, noob here.
This ones good... Read my comment on the last page
http://www.ft86club.com/forums/showthread.php?t=19218
For the differential, if you're using Motul that has the built-in spout it's a little hard to get the final drops out of the bottle. I added this remaining fluid to a fresh bottle then continued my fill. My diff held a little under 1.3L.
With the transmission, once you squeeze out what you can from a bottle into the transmission, you can then wedge/prop the bottle above the fill hole draining downwards and let the remaining fluid run out by itself. It goes a little slow because there's no air vent but it shouldnt take more than 3-4 minutes.
Motul bottle wedged upside down (above transmission) to fill what I couldn't squeeze out:
akahenry (11-08-2014), Ganthrithor (07-14-2014)
Old 07-13-2014, 08:35 PM   #8888
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Thanks! They're actually pictures that my buddy took with his Canon Rebel T2i, both 10-20mm lens and 50mm f/1.4. I shoot with a Nikon D5000, typically my standard 35mm until I can purchase a Tokina 11-16mm f/2.8 II wide angle.
The Following 2 Users Say Thank You to chanomatik For This Useful Post:
AznKirby (07-14-2014), wtrxprs007 (07-14-2014)
Old 07-13-2014, 10:07 PM   #8889
Candlejack
Candlejack's Avatar
Also new exhaust!!
Attachment 84916
And rain..
Attachment 84917
There are some very tiny tabs (two on one side, and one on the other) that you'll need to trim off. But it's easy work. The stock bulbs have them, but the LED bulbs are slightly off-alignment (one is on the wrong side of the bulb). But when you trim them off it still fits very snug and clicks in.
The color looks great. It's a little on the blue side, but that's probably because it's next to the 4500k headlights. But definitely > stock.
The Following User Says Thank You to Candlejack For This Useful Post:
jimmillion (07-14-2014)
Old 07-13-2014, 10:33 PM   #8890
anewprelusion
I removed my front lip today because of this...
anewprelusion is offline   Reply With Quote
The Following User Says Thank You to anewprelusion For This Useful Post:
