Old 07-11-2014, 01:05 PM   #1
ddeflyer
Rear brake pad lifespan
As they are on the rear, I don't really have enough opinion to post in the brake pad thread about this, but I figured it wouldn't hurt to let people know that I got 16 track days and 9500 miles out of Ferrodo DS2500 pads on my rear brakes. This is without pedal dance or anything like that. One pad was worn past the wear grove, the other three still have some of the grove visible (not sure why only one pad). Dust boots were still pretty intact (only noticed a small amount of crustiness on one of them) so I don't think I really cooked the rears too much at any point.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 07-11-2014, 01:55 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
hold on a second
so what you're saying is
there are brake pads in the rear... and they wear?
Old 07-11-2014, 03:02 PM   #3
ddeflyer
Originally Posted by 7thgear View Post
hold on a second
I'm saying that I got 9500 miles and 16 track days out of DS2500 on the rears...
The idea being if you are using DS2500 and you are getting close to either of those values you might want to take a wheel off and check the wear indicator groves more frequently.
Alternatively, if you are thinking about using those pads which cost $160, you could have an idea what your running costs will be.
In the end I am trying to provide some information that at one point I would have liked to have had; you know, for the good of the community and such.
The Following User Says Thank You to ddeflyer For This Useful Post:
acro (07-15-2014)
Old 07-11-2014, 03:15 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I'm just making a funny
that's a very short life for rear pads!
Old 07-11-2014, 03:38 PM   #5
wheelhaus
wheelhaus's Avatar
I would agree <10k miles is short except for the part about 16 track days. If that's four 20 minute sessions each day, that's over 21 hours of on-track time... Depending on the track and driving style, that might not be so bad.
My buddy roasted through a new a set of DS2500's on an old E30 325 in 4 track days.
Old 07-11-2014, 03:50 PM   #6
ddeflyer
Most of them are actually 5, 20 minute sessions, so more like 27 hours of on track time. Overall the tracks I've been on are probably in the moderate to hard on brakes range (mostly T-hill, Buttonwillow and MRLS). By that I mean I am able to get endurance pads up to bedding-in temperatures on the fronts without any trouble.
Old 07-11-2014, 04:33 PM   #7
CSG Mike
CSG Mike's Avatar
What front pads/setup are you running?
Also, what tires are you running?
What kind of power are you putting down?
Brakes are one of those YMMV things...
CSG Mike is online now   Reply With Quote
Old 07-11-2014, 05:44 PM   #8
Pat
Pat's Avatar
Drives: 2023 BRZ
sup.
16 track days is a LOT.
Old 07-11-2014, 05:49 PM   #9
ddeflyer
Front brakes have been Essex sprint the whole time, started off with DS2500 for street and DS3000 for track, got lazy and mostly used DS3000 which kind of turned to dust on the freeway. Now using DS 1.11s and keep meaning to swap back to DS2500 for street use. I never tried the DS2500 on track and when I started I wasn't even getting the DS3000s up to temp. I didn't realize for quite a while that I hadn't even managed to get them bedded in until I was half way through them (took me a while before I gained the necessary skill to hit higher speeds and threshold brake enough to get them to bedded in).
Started off with Michelin Pilot Super sports, now using Yokohama Advan AD08Rs
Power is stock, only engine mods are catch cans and oil cooler.
Alignment started off with stock, then got crash bolts to -1.2 camber in front, nothing in rear, 0 toe all around. Got it changed more now but that doesn't matter since the pads are off :p
Old 07-11-2014, 05:50 PM   #10
ddeflyer
Originally Posted by Pat View Post
sup.
Best way to learn is to do something a bunch of times in rapid succession. That way you keep a constant train of thought and have comparable experiences.
Old 07-11-2014, 07:06 PM   #11
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
sup.
It's all relative. Some drivers go once or twice a year, and some are out there 40-50 or even more days a year.
dradernh is offline   Reply With Quote
Old 07-11-2014, 07:25 PM   #12
CSG Mike
CSG Mike's Avatar
I'd recommend you use the same compound front/rear. You're probably noticing that the fronts wear faster than the rear; that's because theyre doing more work. You want to distribute the work as best as you can to even out the wear.
If you're not doing the pedal dance, then the ECU is distributing the brake force as best as it can for you automatically.
Old 07-11-2014, 07:48 PM   #13
ddeflyer
yeah, originally I choose the compound distribution because I didn't think I would be going pretty much every other weekend and I wanted to keep the noise and dust more in check. I was figuring that the rear brakes would be more work to swap than the fronts so I just kept with one compound for the rear. Then I kind of stopped swapping the pads and after mucking up some rotors in the process I realized that I should be swapping rotors also which was alot of work :p
I'm not yet doing the pedal dance but it is something I want to move up to; so far I have only tried it on some autocross runs.
Old 07-11-2014, 08:23 PM   #14
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I've been running the Ferodo DS2500s front and back on and off the track for a year now. About 15,000 miles, with 10 track days. I still have considerable life left on the rears, while the front's may only see one more track day.
They squeal a bit when it rains, and even have had them stick to the rotor if you park with wet rotors ...
Other than that - been really happy with their performance. I'm most likely going with the track only 1.1s as well as the DS2500s when I buy pads next.
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 03:23 PM
rear brake noise norcal_brz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-19-2013 04:25 PM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 03:39 PM
rear brake pads donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-05-2013 11:43 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
