Old 07-11-2014, 05:47 PM   #1
ThePoet
Drives: Scion FR-S
Big brown DRL fuse.
If I pull this fuse will it turn off my DRLs? I assume I'd lose my high beams as well if I did this? I did a search but didn't come up with any conclusive answers. And also, is it just as easy as plugging the fuse back in to turn the DRLs back on if I wanted to? Thanks in advance!
ThePoet is offline   Reply With Quote
Old 07-11-2014, 05:56 PM   #2
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
FYI:
http://www.ft86club.com/forums/showthread.php?t=7435
Cockatoo is offline   Reply With Quote
The Following User Says Thank You to Cockatoo For This Useful Post:
continuecrushing (07-11-2014)
Old 07-11-2014, 06:01 PM   #3
ThePoet
Drives: Scion FR-S
Right, I had found that and I might end up doing that, but I really just want to know if the fuse does the same thing or not and if its going to hurt anything
That thread kind of just turns into a dead end.
Old 07-11-2014, 06:58 PM   #4
cfordart
cfordart's Avatar
Drives: 2014 FR-S
http://www.ft86club.com/forums/showp...2&postcount=89
Do this DRL relay replacement with that relay from NAPA. Worked for me, 5 minute job. DRLs off, everything else works like original. Relay is $25, but it makes it easy to go back to stock, just swap it back out.
cfordart is offline   Reply With Quote
Old 07-11-2014, 07:15 PM   #5
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
You can get a Mini VCM cable from Amazon cheaper than that and can turn your DRLs off the right way, fix seatbelt chimes, single stage unlock, etc. Just saying...
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 07-12-2014, 06:28 AM   #6
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Yeah.... we're lucky here to have access to the mini VCM and TechStream software, so just do it as it's meant and turn them off in the customisation menu. Worse case, just ask the dealer to do it, can't believe it will cost anything much
Harvey is offline   Reply With Quote
Look at what the brown truck brought! D K Engine, Exhaust, Transmission 0 07-03-2014 04:53 PM
brown bear suBROru Northwest 1 07-27-2013 02:49 PM
Kevin Brown Paul_S Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 03-20-2013 06:39 PM
Are Your Tires Turning Brown? Veloist Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 01-27-2013 08:00 PM
Sometimes dogs are brown Wesley Scion FR-S / Toyota 86 GT86 General Forum 13 10-22-2012 08:32 PM
