#995 | |
Grip>Drift
Drives: FRS
I've got almost 70k miles on my FR-S and about 60k has been on the KWs btw.
#996 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#997 |
Grip>Drift
Drives: FRS
They are still the same as when I bolted them on the car! I also live in sunny California so they hardly even see rain so no weather deterioration. If I cleaned them up they would still look brand new. I've gotten my moneys worth out of them for sure!
| The Following User Says Thank You to BlaineWasHere For This Useful Post: | Scooby South (07-02-2014) |
#998 |
Drives: '14 BRZ
#999 | |
Drives: Whiteout FRS- autocross ready
As far as the "model" definition goes, I read that as the parts are legal across all the model variants if they are legal for one (although they are talking about variants within one manufacturer's lineup). The problem is I have an FR-S and I do not believe Scion/Toyota sells a front splitter in the accessories catalog. There may be a TRD part, but that is the performance catalog. Since the FR-S and BRZ front fascia are different they are not interchangeable. Does anyone see this differently? And more importantly does anyone know of a front splitter U.S. accessory from Scion Toyota? If they have one you could then buy any comparable splitter from aftermarket suppliers.
#1000 | |
Conedancer
Bill
#1001 |
Conedancer
This was in 2009.. I think 2010 or 11 they outlawed Aero stuff
![]() Bill
#1002 |
Drives:
I was struggling like crazy for rear grip this weekend. I'm always fighting oversteer at this particular venue.
I have RCE Tarmac 2's and a Whiteline 22mm front bar on the stiff setting. Stock rear bar. Would I be nuts to go to the soft setting on the front bar and ditch the rear all together? I've tried multiple settings with rebound/compression but even with the rear rebound 2 clicks from full soft she still gets tail happy.
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
#1003 | |
Drives: 2013 Cayenne turbo
I don't think anyone would consider it nuts if it made the car hook up more. Chances are, people would be wondering what you did. I did this on my VW GTI as well (on the rear bar). I had a vastly stiffer rear bar than stock, but still stock up front for G-Street. I had to run the softest setting possible to keep the car from drifting. The soft setting is still more stiff than stock, so it is still an improvement. Another option (for ST_ anyway) is to put a matching rear bar on your car. It just depends how tied together you want the left and right sides of your car.
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#1004 | |
Conedancer
just to know what to recommend. Bill
#1005 |
Yes alignment and rake are important!
Also, where is the oversteer occuring? Entry, exit, mid-corner? - Andy |
#1006 | |
Drives:
2 degrees rear camber. 3.3 degrees front camber. Rake was almost .5" higher in the rear but I've since fixed that.
My STX build thread
#1007 |
Drives:
Entry and mid corner mostly
My STX build thread
#1008 |
Try giving it up more prior to the elements and concentrating on late apexing everything. That fixed my early corner push problems and is usually a much faster line as well.
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
