Old 06-29-2014, 11:27 AM   #1
Opposed
Drives: 2013 Asphalt FR-S
Help! Ecutek problem
Hey everyone. I am returning my car back to stock after being boosted. It was tuned on BRZedit, but I am now attempting to flash it back with my old Ecutek N/A tune. I am getting an error code 37 "security violation time delay" when trying to query the ECU. My car is now stuck at the shop. Anyone heard of this?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 06-29-2014, 05:10 PM   #2
steve99
Drives: FT86
Sounds like a licensing issue.
As you overwrote your ecutek rom with brzedit you will have lost the ecutek liciencing info in the ROM in the ecu.
you will have to contact your tuner or ecutek to get the licience re-issued.
Brzedit could also be the problem as it changes the seed keys and prevents anything else from writing to ecu. If you can flash a stock rom with brzedit you should be ok.
stock roms here at end of post
http://www.ft86club.com/forums/showt...xtrix+ecuflash
Old 06-29-2014, 05:16 PM   #3
Opposed
I think your right. I was able to flash the stock ROM file from BRZedit. I was them successfully able to query my ECU with Ecutek, but then it said I have zero license remaining. That could most likely be the issue. Well, either way, I am no longer stuck at the shop since I am on the stock ROM file. Car is drivable.
Old 06-29-2014, 05:23 PM   #4
steve99
Drives: FT86
Ok if thats the case you have to get your licence renewed form your tuner or ecutek.Ecutek embeds licience info in any roms it writes to your ecu. If you write with anything else you overwrite the licience and your snookered. Unless you saved a copy of the stock ecutek rom with embedded licence info and can write it back with something like tactrix maybe.
Opposed (06-29-2014)
Big Problem jpit Engine, Exhaust, Transmission 156 05-13-2014 09:21 PM
map problem ecutek tune. ChinoAnthrax Software Tuning 8 05-05-2014 03:57 PM
DRL problem benlaz88 Scion FR-S / Toyota 86 GT86 General Forum 23 09-19-2013 09:58 PM
ecutek firmware problem ahk Software Tuning 5 07-29-2013 11:31 AM
ecutek deskey problem!! ahk Engine, Exhaust, Transmission 17 03-07-2013 04:54 PM
