Old 06-24-2014, 09:23 PM   #1
BadBRZ
Drives: Subaru
smallest OD coil over / spring perch
If i wanted to go as wide as possible on the tires I'll need the slimmest coil, any suggestions?
BadBRZ is offline   Reply With Quote
Old 06-26-2014, 12:16 PM   #2
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
KW V3's use 2.5" coils
KW V3's use 2.5" coils. Those are just about as skinny as you're going to get.
KoolBRZ is offline   Reply With Quote
Old 06-26-2014, 12:19 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
What size wheels? Most aftermarket coilovers will allow you to run 9.5" up front without issues... and if you're running wider than 9.5" in the front, you're doing something wrong.
http://eibach.com/america/en/motorsp...cation-look-up
Springs as small as 41mm ID but you'd need a custom coilover setup for this car.
-alex
Old 06-26-2014, 02:08 PM   #4
BadBRZ
Drives: Subaru
Was hoping to get a 10" rim at +38
Old 06-26-2014, 03:00 PM   #5
CSG David
CSG David's Avatar
That's a fat wheel for a car that can't even utilize the capability of a 265 on a 9.5" with 500hp.
The Following User Says Thank You to CSG David For This Useful Post:
wparsons (06-27-2014)
Old 06-26-2014, 08:15 PM   #6
BadBRZ
Drives: Subaru
Mhmm, thats why i need a 10" wheel and a 285
Old 06-26-2014, 08:29 PM   #7
CSG David
CSG David's Avatar
Drag racing or autocross?
Old 06-26-2014, 08:32 PM   #8
BadBRZ
Drives: Subaru
Both
Old 06-27-2014, 10:33 AM   #9
wparsons
wparsons's Avatar
I think you misread David's post... he was saying that a 265 on a 9.5" wheel is more tire than these cars need with 500hp. I seriously doubt you'll be any quicker around any sort of course with 285's than with 265's.
If you were really serious about handling you would realize that a GOOD coilover setup with 9" or 9.5" wheels will give you better handling than an inferior one that lets you run a 10" wheel.
flickr
Old 06-27-2014, 10:38 AM   #10
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Both
You cant have everything. There are always compromises.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 06-27-2014, 12:56 PM   #11
BadBRZ
Drives: Subaru
Thanks all
Clearance to spring perch Gearhead1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-07-2014 05:56 PM
Stance Coil overs or BC coil overs ? tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 11-26-2013 04:13 AM
WTB RCE spring or RS*R spring mounted on stock strut jshum Want-To-Buy Requests 1 10-11-2013 02:47 PM
What's the smallest oil cap? Hanakuso Engine, Exhaust, Transmission 2 07-08-2013 03:55 PM
Coil-overs \ Spring kit ????? v3rgil AFRICA 9 11-16-2012 08:27 AM
