Drives: Subaru
smallest OD coil over / spring perch
If i wanted to go as wide as possible on the tires I'll need the slimmest coil, any suggestions?
#2 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
KW V3's use 2.5" coils
KW V3's use 2.5" coils. Those are just about as skinny as you're going to get.
#3 | ||
Drives: 2005 Toyota Camry
Springs as small as 41mm ID but you'd need a custom coilover setup for this car. -alex |
#4 |
Drives: Subaru
Was hoping to get a 10" rim at +38
#5 |
That's a fat wheel for a car that can't even utilize the capability of a 265 on a 9.5" with 500hp.
#6 |
Drives: Subaru
#7 |
#8 |
Drives: Subaru
Both
#9 |
I think you misread David's post... he was saying that a 265 on a 9.5" wheel is more tire than these cars need with 500hp. I seriously doubt you'll be any quicker around any sort of course with 285's than with 265's.
If you were really serious about handling you would realize that a GOOD coilover setup with 9" or 9.5" wheels will give you better handling than an inferior one that lets you run a 10" wheel.
#10 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
#11 |
Drives: Subaru
Thanks all
| Clearance to spring perch | Gearhead1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 03-07-2014 05:56 PM |
| Stance Coil overs or BC coil overs ? | tr1x5tuh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 36 | 11-26-2013 04:13 AM |
| WTB RCE spring or RS*R spring mounted on stock strut | jshum | Want-To-Buy Requests | 1 | 10-11-2013 02:47 PM |
| What's the smallest oil cap? | Hanakuso | Engine, Exhaust, Transmission | 2 | 07-08-2013 03:55 PM |
| Coil-overs \ Spring kit ????? | v3rgil | AFRICA | 9 | 11-16-2012 08:27 AM |
