Old 06-25-2014, 07:40 PM   #99
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
I think you should give @ModBargains a call. They do Full Blown installs if I'm not mistaken. If you're having a shop install for you I suggest you ask them about cooling, clutch and gauges for your type of usage. They should be able to point you in the right direction.
Forums too - do lots of research.
rb6freak is offline   Reply With Quote
Old 06-25-2014, 09:20 PM   #100
jc1993
Drives: 2013 all stock frs
Sure, but I would grab a clutch and gauges first.
Really? Stock clutch won't hold 7psi??
jc1993 is offline   Reply With Quote
Old 06-25-2014, 09:26 PM   #101
jc1993
Thanks bro but Ima go with ur first suggestion and install it myself or with a buddy.
Old 06-25-2014, 11:40 PM   #102
SPCorBUST
SPCorBUST's Avatar
Originally Posted by jc1993 View Post
Sooo I test drove both sti and wrx. I finally experienced the infamous turbo lag but with the wrx it really wasn't the case. It pulled like a beefed up v6 imo. I loved both cars but I just didn't feel right while I was driving. It may sound odd but I felt a little high lol. So with that being said I took ur guys advice (appreciate it) and test drove the vehicles and decided I'm going wit a turbo twin I'm going with fbm 7psi tune just to be on the safe side for now
congrats! you'll love it.
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
jc1993 (06-28-2014)
Old 06-25-2014, 11:42 PM   #103
SPCorBUST
SPCorBUST's Avatar
I will keep u guys updated... Im looking at some options for cooling.. do u think I should grab fbm oil cooler or upgraded radiator? ???
the Robispec combo is supposed to be pretty good
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
jc1993 (06-26-2014)
Old 06-26-2014, 03:17 AM   #104
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Not for a long time.
JackSmiley is offline   Reply With Quote
Old 06-26-2014, 05:50 AM   #105
CSG Mike
CSG Mike's Avatar
How so? A clutch is either holding or it's not.
Old 06-26-2014, 06:02 AM   #106
JackSmiley
JackSmiley's Avatar
Wouldnt the stock clutch slip after a certain amount of power? And IDK if 7psi is high enough for one to need a clutch upgrade.
The Following User Says Thank You to JackSmiley For This Useful Post:
jc1993 (06-28-2014)
Old 06-26-2014, 06:05 AM   #107
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
go with the fbm oil cooler and radiator + fans, as long as you bought the stage 1 turbo setup it shouldn't have any fitment issues.
Build Thread
Instagram
Old 06-26-2014, 12:43 PM   #108
CSG Mike
CSG Mike's Avatar
Precisely. If its holding, then it's not wearing., so it won't last any less longer.
JackSmiley (06-27-2014), jc1993 (06-28-2014)
Old 06-26-2014, 01:10 PM   #109
sw20kosh
Drives: 2013 Black FR-S
Stock clutch will let go at ~220-230 wtq (dynojet). We found this out during our tuning process where torque was incrementally coming up each revision and finally started slipping at this torque level.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
JackSmiley (06-27-2014), rb6freak (06-26-2014)
Old 06-26-2014, 03:10 PM   #110
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It isn't a question of PSI, it is a question of torque. A good tune on 7 PSI will result in clutch slip very soon after it is installed.
Old 06-26-2014, 10:03 PM   #111
SPCorBUST
SPCorBUST's Avatar
depends on how you're shifting as well. as they're saying, psi doesn't matter - I was at 15 and it was holding fine except for WOT shifts where the rev was being held when shifting. max torque was 252, hp was 330 on the corn, which is all I really run.
Old 06-28-2014, 05:55 AM   #112
jc1993
Thanks so I'll scratch clutch of the list!
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 03:41 PM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 11:47 PM
2015 86/BRZ vs 2015 Eclipse botbs FR-S / BRZ vs.... 55 04-16-2014 05:07 AM
