View Poll Results: What side seal have you had a problem with
Driver's side seal problems 41 47.13%
Passenger side seal problems 4 4.60%
Happend on both sides 19 21.84%
Seal problems? I ain't got no seal problems! 23 26.44%
Voters: 87. You may not vote on this poll
Old 06-24-2014, 07:56 PM   #1
suaveflooder
Window seal problem (pole included)
Just wondering if this is just a bad design, cheap rubber, or side dependent.
I just had my new seal start rolling on itself (passenger side) again. It was replaced less than six months ago. It's not leaking, so I've decided to leave it. I don't want the dealer to have the car again and it seems pointless as it'll just work for a couple months and start all over.
So, how are we looking? What side seal have you had issues with. For those of you who don't know what I'm talking about, it's this:
This is a friend of mine's car.
I'm wondering if it has something to do with oils coming out of the rubber (even if it's synthetic). My seal got a little tacky when it started rolling. Might sound crazy, but there are threads about the steering wheel getting sticky randomly and then just going away (mine did this). I currently have a piece of 4 guage amp wire (hidden when the window is up, so it doesn't look bad) to hold the seal in the correct place. In the last two days, the "sticky" feel of the seal has gone away again. Still going to leave the wire in there for another couple weeks and see what happens. Hopefully, it's like the steering wheel and just goes away. Based on how it felt today, I'm beginning to think it might.
suaveflooder is offline   Reply With Quote
Old 06-24-2014, 07:58 PM   #2
kALMIGHTY
Drives: TRD Ultramarine '13
I've had the car for 11 months now and no issues. Seems to be a hit or miss with these cars.
The Following User Says Thank You to kALMIGHTY For This Useful Post:
suaveflooder (06-24-2014)
Old 06-24-2014, 08:07 PM   #3
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I had my driver side replaced when I got my 2nd oil change. About 15 months, 14k miles.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Old 06-24-2014, 08:15 PM   #4
suaveflooder
I'm thinking that too. There are quite a few of us that go to C&C in Carlsbad, and I've only seen 3 out of 8 or 9 of us with the problem. I'm hoping mine just goes away. I put some wurth conditioner on it yesterday. It's designed to help the window not freeze. Different problem, I know, but worth a shot.
Old 06-24-2014, 08:23 PM   #5
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
I've got the same thing happening on both sides, and it's been like that for over a year. I tried lubricating it with silicone, white lithium grease, cleaning it real well , etc., with no improvement, so I just let it be. As long as it doesn't leak, I'm not worried.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
The Following User Says Thank You to SportInjected For This Useful Post:
Old 06-24-2014, 08:25 PM   #6
suaveflooder
EXACTLY! My windows are tinted. Only reason why I noticed the passenger side both times was because the seal was out of place. I put it back and added the wire. Just going to let it sit for now. No leaks as of yet and no one can tell with the door shut
Old 06-24-2014, 08:31 PM   #7
kALMIGHTY
Yeah, I've been lucky with some problems and not so lucky with others. For example, I've never had the crickets, but I did have that rear deck ticking which got fixed but now it's back again
My TRD exhaust made a weird sound but they never found the source so they didn't replace it under warranty so I ended up just selling it.
TLDR: You win some, you lose some.
Old 06-24-2014, 08:38 PM   #8
suaveflooder
Agreed. Such a weird, quirky, fun car! Just like a woman
The Following User Says Thank You to suaveflooder For This Useful Post:
kALMIGHTY (06-25-2014)
Old 06-24-2014, 09:19 PM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Wait what constitutes a problem for the poll? (lol poles are for firemen and strippers)
Both sides of my car have seen the seals roll up, neither have leaked and they both look a little rough around the edges (some people flipped out about them deteriorating).
ineedyourdiddly
Old 06-24-2014, 09:20 PM   #10
roddy
roddy's Avatar
Drives: '13 Ultramarine
My passenger side has done it pretty much from day one (2 years now). The driver's side just started recently. I haven't bothered to take it in for a "repair" that will likely be as successful as the cricket fix.
The Following User Says Thank You to roddy For This Useful Post:
Old 06-24-2014, 09:45 PM   #11
stugray
Drives: 2013 GBS BRZ Limited
I have never seen my car do that.
It is a 13 with 18k mi. original seals
For a lube, one more thing you can try is glycerine.
It is used to condition rubber seals.
Drug stores can get it for you.
Old 06-24-2014, 09:49 PM   #12
stugray
The tint has a greater coeff. of friction on the inner surface than the stock glass surface. Seal cant slide like designed
Old 06-24-2014, 09:57 PM   #13
suaveflooder
Notice the origional post. It's my buddies car……there is no tint. Tint is a poor reason why the seals are sticking. It has nothing to do with tint. It's a crappy design or crappy material. My vote is design flaw. This is not the first car I've seen with no tint with the issue
Old 06-24-2014, 10:14 PM   #14
stugray
Sorry I missed the "friends car" and saw your "tinted" comment
If it was a "design flaw" then ,by definition, it would happen to ALL of them.
I suppose if you didnt "design" it with adequate variation or parts stack up in mind then..... ok.
More likely a supplier problem with the compound of the rubber in the seal.
And some automotive windows have an inner layer in the laminate so the window doesnt blow up in your face in an accident.
variation in that layer could do it.
Anyone broken a side window yet?
Does it turn into a pile of tiny pieces, or stay together in a sheet?
The Following User Says Thank You to stugray For This Useful Post:
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 06:12 PM
Drivers Side Window (Not Seal) Mister Issues | Warranty | Recalls / TSB 20 12-16-2013 03:56 PM
Window Seal Leaves Marks on Windows AsianStyle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-22-2013 04:28 PM
Does anyone else have this problem after lowering their BRZ? (pics included) Calin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-28-2013 12:59 AM
