#127 |
If you are confident that there is no leaks, just disable the DTC.
#128 |
Drives: SWP BRZ
Thanks for your efforts to help overcome our crappy fuel steve99.
Since reading this post I am running 100ron exclusively, though haven't loaded your tune as I have been running a prototype Phantom ESC with Shiv's G rom ESC tune. With s2d4's assistance I have a 3rd - 4th gear pull from earlier this week.Would value your thoughts on how this looks and which parameters I should be logging to see if I am getting any knock. Exhaust/filter are stock. ![]() http://www.datazap.me/u/gums/aussie-esc-pull-100ron Last edited by Gums; 06-06-2014 at 03:40 AM. Reason: link |
#129 | |
Drives: FT86
for knock log RPM THROTTLE FBKC KNOCK CORRECTION KC LEARNED ( we can derive flck from this) IAM try FLKC but is probably suspect Engine LOAD PROBABLY WORTH LTFT FUEL SYSTEM STATUS OL/CL AFR COMMANDED AFR got no experience with the phantom esc but we will be able to see if its knocking Last edited by steve99; 06-06-2014 at 05:47 AM. |
| The Following User Says Thank You to steve99 For This Useful Post: | Gums (06-06-2014) |
#130 |
Drives: SWP BRZ
Thanks Steve,
Bit of a noob when it comes to this, added link in previous post to datazap |
#131 | |
Drives: FT86
RPM THROTTLE FBKC KNOCK CORRECTION KC LEARNED ( you can derive flck from this but you will need to look at the Ignition Advance Max A table) IAM try FLKC but is probably suspect Engine LOAD It looks a bit suspect where the KC Learned is stepping down at higher rpm on towards the end the third rpm peak. But you really need to log LOAD and knock correction and FLCK to make sense of it. It might just be the tune reducing advance as load rises under boost ![]() http://www.datazap.me/u/gums/aussie-...1-2-5-6&solo=5 I think your better off sending the logs to Shiv and let him look at it
#132 |
Senior Addict
Drives: 86 GT
I did a power run on a dynapack yesterday, as I've never dyno'ed this car before. Here are the results:
http://s9.postimg.org/kevmjohnz/2014...527_Page_1.jpg This chart overlays a run taken from stock BRZ which was done on the same dyno: http://s9.postimg.org/g70uaxg8f/2014...527_Page_2.jpg My tune was done by @jamesm from HRI Tuning. Only other mod is a Motiv catted front pipe. I felt that I really needed a custom tune instead of a canned tune because the of the crappy fuel here...even on 98RON...and the ECU's hyper-sensitivity to fuel quality. Anyways, what I noticed was that the AFR readings from the dyno run doesn't quite match the readings taken from my OFT logs. Can someone chime as to why? Here's my most recent data log taken couple of days ago: http://datazap.me/u/fizz/hrilog11?lo...1&zoom=33-2077 The AFR's from the dyno appears to be quite lean at WOT...?
#133 | |
Drives: FT86
#134 |
The placement location would be another variation as well unless it is at the rear oem o2 sensor, even then they won't be exactly the same.
![]() Last edited by s2d4; 06-20-2014 at 03:17 PM. |
| The Following User Says Thank You to s2d4 For This Useful Post: | steve99 (06-19-2014) |
#135 |
Senior Addict
Drives: 86 GT
Ok thanks guys....makes sense now. But still curious which is the more accurate/true reading? The sensor from dyno, or sensor from car?
If the reading from the dyno is a better reflection of actual conditions, that means I'm potentially running too lean at WOT? Or am I worrying too much? |
#136 | |
Drives: FT86
hopefully the dyno's O2 would be more accurate as they would check its calibration. |
#137 | |
Did you ever do one with just Shiv's tune?
#138 |
Senior Addict
Drives: 86 GT
#139 | |
Looks like power did drop in that area because of it though, a bit of a balancing act I guess.
#140 |
Drives: UK GT86
The dyno O2 sensor will be exposed to more ambient air and is after 1/2 cats depending on your exhaust configuration so it will read leaner probably by a good 0.1-0.2 AFR points minimum. As for which one to trust, that's down to you. I've heard reports recently of someone I know having 3 sensors in the exhaust pre-cat (inc. 1 OEM) and one in the tail pipe. They all read differently, so again, do you trust 1/none/all??
Feed it back to James and see what he says. So long as its not knocking I don't see an issue so long as you're not lean at the top end, which you're not.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | steve99 (06-19-2014) |
| Knock Correction vs Knock Correction Learn values? | swift996 | Software Tuning | 19 | 11-03-2015 10:09 PM |
| Dynosty Fuel System Upgrades- Billet Fuel Rails!!! | Dustin@Dynosty | Forced Induction | 4 | 10-08-2014 10:00 AM |
| FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. | MmmDieselFumes | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 02-02-2014 08:19 PM |
| Fuel gauge misreading actual fuel in tank. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 10-09-2013 03:39 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
