Old 06-15-2014, 02:59 AM   #15
steve99
Drives: FT86
Originally Posted by Astroboy View Post
Avo, only 2k miles boosted..
Could the vibration be limp mode maybe?
limp home mode usually involves running engine in a safe or base mode, limits power output most likely disables/limits intake/exhaust VVT, slow throttle response low power, unlikely it would introduce severe vibration, and it would generally be the result of the ecu detecting failed sensors or systems and throwing up a cel code as a result.
Sounds more like misfire, fouled plugs, crook coil pack, bad vaccuum/boost leak although you would expect it to throw up a CEL code.
Best get someone to look at it before any serious damage done, and it turns into a loud mechanical clatter.
Astroboy (06-15-2014)
Old 06-15-2014, 07:34 AM   #16
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
See a mechanic.
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
The Following User Says Thank You to kiichiro For This Useful Post:
Old 06-15-2014, 09:39 AM   #17
mike the snake
Check the vacum line under the intake manifold.
The Following User Says Thank You to mike the snake For This Useful Post:
Sportsguy83 (06-16-2014)
Old 06-15-2014, 12:00 PM   #18
Astroboy
Astroboy's Avatar
Drives: None
I experienced something like this on Thursday too, while it was raining. The situation was on the way to school, exactly 3 minutes before I parked, except that time it felt like a loose wheel of some sort.
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 06-15-2014, 12:29 PM   #19
Astroboy
Astroboy's Avatar
Drives: None
But on that Thursday it wasn't as wobbly
Old 06-15-2014, 01:39 PM   #20
onzippy
Drives: 2014 FRS
The spectrum of your description is wide. Do you think it is an engine vibration or a chassis issue? I mean, do you feel it only when the vehicle is moving or maybe get some erratic feedback from the steering wheel?
Engine wobble on the passenger side is hard to conceptualize.
With the AVO base map I would get misfire events that do not trigger a CEL. It flashed the check engine lihght while occurring and save it to the ecu. With the scan tool you can see a history if that's what it was. This would happen to me after hard driving and my opinion is the basemap is overly rich mixture for safety and that cause it... even if not related, get a proper tune if you haven't already and a mechanic.
onzippy is offline   Reply With Quote
Old 06-15-2014, 02:04 PM   #21
onzippy
Drives: 2014 FRS
.... I pulled over drove 15mph and the thing was wobbling like crazy still. Then I turned it off and cranked it back up and the car was shaking, almost like a roller coaster, on the passenger side when starting.
I just read your post again and when you say "starting" I keep thinking you mean moving.... so that plus roller coaster and I'm thinking your front tire looks something like this... (tire bubble)
The Following User Says Thank You to onzippy For This Useful Post:
Old 06-15-2014, 03:01 PM   #22
Astroboy
Astroboy's Avatar
Drives: None
God I wish that was the case
Old 06-15-2014, 06:30 PM   #23
Astroboy
Astroboy's Avatar
Drives: None
So I turned on my car and there was no wobbling today.... which is weird. Should I still be concerned?
Old 06-15-2014, 06:45 PM   #24
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Yes intermittent misfires almost always return. If it is intermittent it is most likely electrical historically with a subaru it is corrosion or a bad connection in with the plug that goes into the distributor or the distributor it's self.
Sent from my Q10
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
Old 06-15-2014, 07:27 PM   #25
Astroboy
Astroboy's Avatar
Drives: None
Sent from my Q10
so it's not that start of direct injection failure and instead just a little spark plug failure...? I can send you a vid through my cell phone if you don't mind.
Old 06-15-2014, 07:28 PM   #26
Astroboy
Astroboy's Avatar
Drives: None
unless the tire moves at start up, this might be an issue
Old 06-15-2014, 07:40 PM   #27
Accurate Race Shop
Drives: Scion FR-S
Yeah you can post a video preferably under the hood at idle. That will give me the best idea if it is a misfire.
Sent from my Q10
Old 06-15-2014, 08:58 PM   #28
Astroboy
Astroboy's Avatar
Drives: None
I was testing it that Saturday night, and when I steered it all the way to the right, on a downhill slope not moving, it would shake...
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Ugh! Car won't start :( FRSGIRL❤ CANADA 53 05-10-2013 04:52 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Tad's CBS BRZ From The Start Tad_07 Member's Car Journals 8 10-12-2012 02:19 AM
